I just cannot decide what to do
Originally posted by LexusFiend
be shooting for around 600 hp and i have always wanted a 6sp tranny ... and i dont think it will cost 10k if i do the work myself im estimating no more than 5k ....
Here is the basic list of what i needed just to get my GTE swap on the road, not including any real performance modifications and no labor costs:
Item / Retail
2jz-gte $3,500
Getrag $1,500
clutch, etc $700
driveshaft $500
Lsd $500
rebuild kit $800
Oil pump $150
Water pump $120
Oil Pan reuse GE
mounts $150
FAL fans $200
usdm 550 injectors $150
injector resistor $100
walbro pump $100
usdm harness $850
hks vpc $700
apexi safc $300
usdm ecu $300
tach conversion $40
custom ic piping $200
spearco fmic $550
bov $200
total $10,710
Now i'm sure you can cheap out and knock another few $k off, but in the long run, you'r gonna need those parts anyways.
Item / Retail
2jz-gte $3,500
Getrag $1,500
clutch, etc $700
driveshaft $500
Lsd $500
rebuild kit $800
Oil pump $150
Water pump $120
Oil Pan reuse GE
mounts $150
FAL fans $200
walbro pump $100
usdm harness $850
hks vpc $700
apexi safc $300
usdm ecu $300
tach conversion $40
spearco fmic $550
bov $200
total $10,710
Well you can always go steal an mkiv TT, swap it all over and blow up the chassis and the rest of the evidence. That would be under $5k, haha.
i concur... just finding a coomplete 2jzgte for under 5g with teh getrag would be hard
let's say we can find one for 5k... we still have at the very least:
clutch-700 (can't trust the old clutch unless you know the history)
walbro pump - 110
US harness - 400 (is there anyway to extend the JDM harness?)
US spec ECU - 450 (if you go with the US spec harness)
custom IC - $$$
i'm thinking about just getting the 2jzgte motor... and getting the R154 tranny...
walbro pump - 110
custom IC - $$$
Mortgage Slave
Just curious as to why everyone wants the JDM 2JZ motor? I thought that the US and Euro-spec 2JZ's had a bigger fuelling system (which I always though was the biggest difference between the JDM and US/Euro-spec 2JZ's)??
ummagawd, for that price range (about $5000) I'd be looking at the 1JZ with an auto (plus fitting), the R154 (from a Soarer) is pretty hard to find, and when you do find one, the person selling usually wants your house for it =\
This is what I'm thinking too. might as well go JDM
I'll want bigger injectors so that fixxed.
The J-spec cams, gone, pretty sure I'll go HKS
The ceramic turbos that self destruct, big deal, I want a big single.
I now have a modded US spec GTE with the mod I would have done anyway.
ECU, I'll go AEM anyways so I'll only need the US wiring harness.
This all make sense to me. That is if I can afford it all at once. Which may not be the case. So I might have to suffer for a bit.
bmsport - check your pm, i have a few questions for you if you dont mind.
I have some connections in japan that i plan to use to source an engine for cheap ... Also im not saying 5k for 600 hp but i think i can do it for 5k for a stock swap but since i have not done the swap yet (hopefully around this christmas). thats all i can say for now lol
LexusFiend
LexusFiend
