squeaky clutch?
i too have this issue as well and the squeaking did stop for a while when i sprayed some liquid lithium grease on the clutch fork and sprayed the whole area where the clutch pedal goes through the firewall. But unfortunately the squeaking returned. I would try to get a buddy to step on the clutch pedal for you while you looked to see where the source of the squeaking is comming from. But im almost 95% sure its comming from the clutch fork.
