Belt pulley came OFF while I was driving?
Old 09-24-04, 08:55 PM
tony400
tony400's Avatar
Default Belt pulley came OFF while I was driving?
I was doing about 65 mph on the freeway when all of sudden a cloud of white smoke came from under the hood. I pulll over and pop the hood open to find the new belt I had recently replace is destroyed. This was Friday and it was about 5 O'clock in the evening. Anyway, somehow the nut on one of the pulley and came off and the pulley fail out causing the belt to be destroyed. How could this happened?
Old 09-24-04, 10:18 PM
/Aerostar\
/Aerostar\'s Avatar
You say you recently replaced the belt...?
Old 09-25-04, 07:12 AM
tony400
tony400's Avatar
Default belt
Yes, that's all I did
Old 09-25-04, 09:46 AM
0l33l
0l33l's Avatar
Did you torque down all the bolts to factoy specs?
Old 09-25-04, 05:23 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
In the words of Ron White.........
It fell off.....
it fell .......OFF.......
IT FELL THE F OFF!
Anyway, somehow the nut on one of the pulley came off
Someone must have been sick on PULLEY NUT DAY.
Old 09-25-04, 05:28 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Joking aside, you really need to invest in a tube of loctite thread locker It'll prevent those little nuisances from happening again.
Old 09-25-04, 06:35 PM
tony400
tony400's Avatar
Default suggestion
O.L.T
I agree with you on the loctite. I replaced the old belt with a new one today. Also making sure every bolts and nuts is tight. As far torqueing it, I just made sure they are really tight.
Old 09-25-04, 06:38 PM
/Aerostar\
/Aerostar\'s Avatar
Default Re: suggestion
Originally posted by tony400
O.L.T
Buy a torque wrench PLEASE. Also, a factory service manual wouldnt hurt. If you need the torque specs, I can look em up for you
Old 09-25-04, 07:56 PM
aliga
Former Sponsor
aliga's Avatar
ot question, when torqueing do you guys torque everything?
im installing the headgasket on my car, and so far only torqued the head bolts and cam shaft cap bolts.
everything else is hand tight.
Old 09-25-04, 08:40 PM
0l33l
0l33l's Avatar
It can't hurt, can it
Old 09-25-04, 09:13 PM
/Aerostar\
/Aerostar\'s Avatar
Thats not advice at all. And yes, it may actually hurt. If you dont know the answer, dont make a random post. I dont mean to be such an ***, but Ive just seen so many of your posts serve absolutely no purpose. No offense or anything, but they just seem like "+1" posts to me
Old 09-25-04, 09:22 PM
0l33l
0l33l's Avatar
Sorry, but no. If the factory put torque specs on certain bolts then they are important. Read how many times the word torque is used in this how-to do the 60k service on a Mitsubishi..
Old 09-26-04, 01:20 PM
/Aerostar\
/Aerostar\'s Avatar
Oh, my bad, I misread the post. I was thinking that aliga was torqueing down something that he would soon redo, something like a headgasket (which should only be torqued down on the final install). But if you are finalizing the install, you should DEFINITELY torque down as much as you can. Buy a torque wrench and get at it.
Old 09-26-04, 07:38 PM
tony400
tony400's Avatar
Default torque
Aerostar,
Would you give me the torque specs. I will borrow a torque wrench from work and use it . Thanks in advance
Old 09-26-04, 07:57 PM
/Aerostar\
/Aerostar\'s Avatar
Hey man, well which bolts are you referring to exactly? When changing your drive belt, you should not be removing any pulleys or anything, just loosening the belt tension via the belt tensioner. Now if you did remove the belt tensioner, the torque on that is a measly 15 ft/lbs. If thats not the one, then describe the onethat you need
Quick Reply: Belt pulley came OFF while I was driving?
