Is the 2jz-ge an interference engine?
If the timing belt brakes on the 2jz-ge, will it bend valves in the head?
Been wondering the answer to this question for a while just nevered posted...
Originally posted by aliga
nope
nope
Originally posted by is300insf
That's interesing. I was reading the IS300 manual off of TIS a while back and thought I saw something stating that it was. I'll look for it.
I found it:. page 1082 EM-18 Engine Mechanical - Timing belt
NOTICE:
If the timing belt is disengaged, having the crankshaft
pulley at the wrong angle can cause the piston head and
valve head to come into contact with each other when you
remove the camshaft timing pulleys (steps 13 and 19), thus
resulting damage. So, always set the crankshaft pulley at
the correct angle.
NOTICE:
the correct angle.
ah crap... I tag along for a fun little question, and it turns into a flip flop flip flop!
So a VVTi head on a GTE block = non-interferance
VVTi GE = Interferance
regular 2JZ-GE = non-interferance
regular 2JZ-GTE = non-interferance
Interesting.
Interesting.
Interesting.
Interesting.
JPI
leksusGS15
04-10-21 07:41 AM
lexixel
05-12-15 11:50 AM
