Engine Management... What To Get First?
Old 10-31-04, 04:59 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Default Engine Management... What To Get First?
Hi guys,
Well my brand spankin' turbos are in... they feel GREAT! Not as quick as the original ceramics but when boost hits I need to feather the throttle so I don't hit the boost cut lol
Anyway, I'm not extracting the best performance out of them since I'm running stock engine management. I'm just wondering what's the most effective way to up the power? Cranking up the boost or sorting out the fuel (too rich)? Which would you guys go for first? I'm looking at getting either:
* A'PEXi S-AFCII and fuel tune
* GReddy eManage and fuel/ign tune
* A'PEXi AVC-R and tune
Which would you guys go for and why?
Cheers
Jose
Old 10-31-04, 05:02 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Oh BTW,
I'm running stock EVERYTHING besides the turbos... stock injectors etc, so I will only be tuning up to the safe limit on these parts.
TIA
Jose
Old 10-31-04, 09:41 AM
Dew23
Dew23's Avatar
Still trying to find the 440 side feed have not forgot about you stick or auto if stick apexi power fc works great have a 240 we are playing with it on .
Old 10-31-04, 05:35 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Hehehe thanks Dewsc300!
I dunno, I'm really thinking about getting 550cc's but only if I need that much fuel lol... I'm planning for around 450~500hp @ flywheel, would you know when the 440cc's run out of flow (running into wack duty cycles?!?!)
I wish my car was stick... it's an auto
Old 10-31-04, 06:27 PM
whiteSc3
whiteSc3's Avatar
AEM best bang for the buck.
Old 10-31-04, 06:51 PM
mrshabo
mrshabo's Avatar
what about map ecu?
Old 10-31-04, 07:00 PM
G Star
G Star's Avatar
how about a boost controller and a air/fuel controller?
have you done exhaust, intake and intercooler mods yet?
edit: just saw your sig, did you do downpipe upgrade yet? dont forget cam gears and pulleys, huge gains to be had there. good luck and happy boosting man.
Old 10-31-04, 09:36 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
AEM? Aren't they real expensive (for the unit, add-ons) and to tune? I dunno
Calvin, I've got a 3" cat. back exhaust system (inc. hi-flow cat, twin resonators), will be doing the downpipe (not the main Y-pipe off turbos yet, don't have enough cash for that yet), I'll have to look into an pulley kit (dunno if I should stick on cam gears... I'm running stock cams?).
Well, it looks like I'll be getting a GReddy eManage fitted and tuned within this month *crosses fingers*... wanna hit at least 200rwkw on the dyno ... pretty reasonable price too, about AUD$660 supplied and fitted, plus around AUD$120 for tuning What you guys think? Yay or nay?
Thanks
Jose
Old 10-31-04, 11:27 PM
whiteSc3
whiteSc3's Avatar
For the tunabilty you cant beat the price. Why do you think most of the supra guys are switching to it, or allready use it.
Old 11-01-04, 12:10 AM
G Star
G Star's Avatar
Thanks
Jose
Hey, I dont know the first thing about the E-manage, but didnt Lex Luthor have nothing but trouble from that thing? I just dont want to see you going through that same ordeal, especially since you are on a pretty tight budget.
Old 11-01-04, 06:04 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Thanks dude, never knew about the problems? I've seen a couple of Soarers fitted up with them... the shop that I went to today just fitted one to another Soarer... search time (again lol)
Old 11-01-04, 06:24 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Default Hmm... Interesting!
Found an interesting article on the eManage from the search!
Greddy E-manage Round II
Mixed results, but it seems be centered around the MAF... and the fact that it's being used on the 2JZGE (distributor type) instead of factory Toyo turbo motors, so I'm thinking that using it on a 1JZGTE shouldn't be much of a hassle *crosses fingers*
Jose
Old 11-01-04, 08:07 AM
mteele
mteele's Avatar
research the MAP ECU
Old 11-14-04, 07:44 AM
Dew23
Dew23's Avatar
Emanage will work ok if you get the set up with fuel and ing harness and amp sensor, will work ok couple of 1j down here running on that set up ,one car made over 900plus at the wheels hope this helps.
scviolence
10-28-10 10:20 AM
stockhatch
10-20-10 06:21 AM
LedZepig
10-29-04 02:17 PM
BLK13X
09-26-04 11:54 PM
LexusRules
02-03-02 11:46 PM
Quick Reply: Engine Management... What To Get First?
