Installed flex a lite fans *pics*
#31
Originally posted by siaxazn
how is this done? do u just cut a hole in the rubber pipe and stick in the thermostat? or is there another way?
also it would be great if someone can point me to a 12v ign switch wire inside the engine bay.
im also excite about getting rid of the vibrations since my new balanced fan blades have come in from flex a lite
#33
i just wedged mine into the opening of the radiator and pipe... used a thin piece of rubber to make somewhat of a gasket and used an extra clamp to keep it still. Works perfectly fine for me
and yes i would like to know a 12v ign wire in the engine bay also
#34
im not really picturing what your saying. It seams my thermstat seams to be a bit large to wedge there at least the screw in part. probably only the tip would fit. Can you describe this better if possible or better yet pics!
Im really tempted to just cut a small hole in the upper rubber hose and wedge it in there as best i can and hope it will stay and not leak. It would be more secure if i placed it in the metal pipe connected to the engine yet i see no way to easily make a hole in that.
#36
Originally posted by aliga
drill
drill
#38
I am considering doing some Flex a lite fans on my car.. I have heard many accounts of 5-15whp from doing it. Anyone notice a difference after doing the fans? Please let me know. Also whats the best fans to use.. I have only been able to find a kit for N/A Supra's which I know will work on the SC's..
Kevin
Kevin
#40
honestly... the only difference i felt was that it was slightly easier to rev... but under load... the difference was quite minimal....
you should get the flex a lite 210's or 220's I dont really know about other electric fans but most people go with these. Just be warned that the fan blades are unbalanced and will cause slight vibration during idle you must contact fal to have them send you free replacement balanced blades and then its all good.
#41
dang... can anyone confirm?
i'm really trying to avoid running a wire through the firewall (MAJOR PITA) for a switched signal for my fan box relay.
I just tapped into the black and red wire on the igniter on the drivers side. also the white and black wire works as well. seams like a good spot sinces its far from any heat so you wont risk burning the wires.
fstlane
GS - 1st Gen (1993-1997)
07-06-12 06:07 AM
