Fuel Pump Location???
Hello CL,
I ve done some searching and I still cant find it. So I have to post.
I cant find the Fuel Pump on a SC400. Plus, I did the jump the fuel pump under the diagnostic cover in the engine bay. Still car is not starting. What does that mean?? bad fuel pump or fuel pump ecu?
I do have sparks.
Any info would be greatly appreciated.
C
I do have sparks.
C
Originally posted by vredniykot
fuel pump is accessible from inside the car, behind the back seat, there is a plate with round lid on it, right behind that plate
CEO
trunk is your sending unit
Originally posted by siaxazn
I'm pretty sure its accessible from within the trunk since I unplugged it once to do a fuel filter change and i started the car a few times and it stalled so i know that was the fuel pump and not the sending unit.
CEO
i must have been high when i removed those
the one that's accessible from inside cabin had hoses connected to it, the one from the trunk had just wires on top
CEO
hmmm on my 92 SC400 the pump is accessible from inside the car, behind the rear seats. a plate covers it and it's right behind it. This is 100% accurate info as I did a walbro pump swap with my mechanic on the car.
dennis
dennis
dennis
dennis
ok i knew the thing was in the tank...thanks D!
CEO
Gentleman
Thank you for all your effort to help. And posting the pic was definitely very helpful.
The fuel pump is right behind the rear seat. Only acessible by removing the rear seat.
The assembly acessible from the trunk is a sending unit.
Anyways, my car didnt start, because I havent driving it or starting it for nearly a month. I checked for sparks and the fuel pump was running. So after jumping the fuel pump. and give it pumping the pedal a few times. It started, So I think that because it has been sitting so long, the fuel line was clogged up.
Anyways, it s running fine now. just like how its supposed to be. This tells me, I shouldnt neglect my lexus, and let it run every few days. I been driving my bimmer for the last month. Let me tell ya, I miss the lexus ALOT!.
Thanks again guys.
Chris
Thanks again guys.
Chris
