car stalls after electric fan conversion??
Old 11-22-04, 10:34 PM
prjctSC300
prjctSC300's Avatar
Default car stalls after electric fan conversion??
afer i installed my electric fan conversion my car stalls when i just let it sit there and idle when hot. i am running the fal 210's. after it stalls i can start it right up with no problem. any suggestions or help?? thanks
Old 11-22-04, 10:55 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
sounds like you knocked a VAC line off when you were under there... maybe forgot a plug on or near the intake, you may have touched it with your arm? etc..... Something isn't plugged in.
Old 11-23-04, 01:01 AM
siaxazn
siaxazn's Avatar
i dunno if it may cause u to stall but hope you remembered to put the fan nuts back on after you took off the stock fan. but i see no other reason why ur car would stall unless you hooked up the power wire to something under the hood in which you shouldnt have.
Old 11-23-04, 06:53 AM
qtb33
qtb33's Avatar
I agree with O.L.T., something has been disconnected and not reattached. I would just go through step by step and simulate what you did and just look carefully around and see if there is anything you may have either forgotten or accidentally bumped and knocked loose. Take your time and look closely.
Old 11-23-04, 07:17 PM
prjctSC300
prjctSC300's Avatar
hmm i double checked everything and it all checks out good. could it be that i wired the relay up wrong?? does anyone have a relay diagram for an electric fan conversion??
Old 12-01-04, 09:41 PM
prjctSC300
prjctSC300's Avatar
i finally found out the problem and got it all sorted out, the fans kick on but only stays on for like 2 seconds. is that normal??
doitlexi
05-06-15 03:15 AM
smokincigs
05-18-11 08:32 AM
Adaa60
SC- 1st Gen (1992-2000)
03-25-11 07:52 AM
BBriBro
01-07-09 07:15 PM
fusion49
11-15-07 08:01 PM
Quick Reply: car stalls after electric fan conversion??
