power steering reservoir
My 92 SC400 is leaking ps fluid from the bottom of the reservoir. I searched and it seems that you can replace the o-ring at the bottom of the tank. The dealership said that there may be an o-ring but they can only sell me the whole reservior for $230. Has anyone actually done this and where did you purchase the o-ring. Thanks
If it does in fact turn out to be an o-ring, they can be had at most auto parts stores - just bring in the original off the pump and ask for a replacement - just be sure to specify that it needs to be designed for use with hydraulic fluid as regular butyl rubber o-rings will swell up and deform.
Originally posted by Nomis
I had a leak on my 95 SC4 resevoir a while back - and it turned out to be one of the two houses - the longer one that connects to the metal tubing. I picked up some hydraulic hose from the parts store, cut it to length and it's been working fine eve since.
Originally posted by mikeloc24
Carson Toyota sells the PS rebuild kit for $30 I believe. I didn't rebuild mine but I'm planning on having it done soon. I believe they also sell the o-ring for like $2 if that's all you want, no guessing games as it's the correct replacement for the bad one you have now.
My bad for taking so long to get back at you guys on this. I don't have the part number but call #800.908.6968 and ask for Gordon is possible. He can do whatever you need
or if you prefer do a quick "search" for Carson Toyota and use that info, it all goes to the same guys. Good luck homies!
Originally Posted by reamemiya
does anyone have a parts # for the rebuild kit from carson toyota?
