HELP: loud wheezing sound under the hood!!!
Old 12-08-04, 09:48 PM
lex400sc
lex400sc's Avatar
Unhappy HELP: loud wheezing sound under the hood!!!
It started as a subtle wheezing whenever I turned the steering wheel while the car was on but not moving (ie: parking, parallel parking) so I figured it to be a power steering problem, but within two days' time the wheezing is now considerably louder and now it's on constantly, changing pitch with my acceleration and steering. Sounds kind of like a sh!!ty old minivan pulling out of a parking space. What do you guys think?? An alternator about to crap out??? I'm afraid to drive her until I've figured out what exactly I need to do to fix her .
Old 12-09-04, 12:18 AM
SupraCoup3
SupraCoup3's Avatar
are you sure you're not low on power steering fluid? (and I'm sure you're well versed about the PS leak )
John
Old 12-09-04, 11:25 AM
lex400sc
lex400sc's Avatar
Power steering fluid is there, but is it supposed to be black like motor oil? The sound seems to be coming from the power steering area of the block, but I'm not sure I could find a leak...
Old 12-09-04, 11:34 AM
rscott
rscott's Avatar
mine did that...i had no fluid in the reservoir.
Old 12-09-04, 11:40 AM
lex400sc
lex400sc's Avatar
Well the reservoir is like a soda can and you really can't see in, but when I pull off the cap, there's black fluid on it
Old 12-09-04, 11:42 AM
jeremyp111
jeremyp111's Avatar
Same for me. The fluid was low so I added some more, turned the wheel from lock to lock to get out the air bubbles and it stopped.
Old 12-09-04, 11:44 AM
lex400sc
lex400sc's Avatar
Hmm.... I guess I'll try adding more fluid
Old 12-09-04, 11:54 AM
lex400sc
lex400sc's Avatar
That helped out a lot!!, but the motor still doesn't idle the same as it did a week ago At least the car is driveable now, I'll have the problem thoroughly checked out at my upcoming 120k. Thanks guys!!
Old 12-09-04, 03:43 PM
/Aerostar\
/Aerostar\'s Avatar
Haha the fluid should not be black...at all. It should look like ATF (because it is ATF ), aka a bright red color. I made a great post on how to flush your power steering fluid a while back, you should be able to find it. Id recommend doing that and seeing if it helps the problem.
Old 12-09-04, 03:45 PM
/Aerostar\
/Aerostar\'s Avatar
Here she is
https://www.clublexus.com/forums/sho...steering+flush
Find an unsuspecting friend and have them help you out this weekend. ANd I would recommend doing this ASAP before your problem gets any worse.
Old 12-09-04, 04:33 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Damn.. someone hasn't changed the PS fluid in a while...
*mental not: get mine done soon lol
I used to get that whirring noise too, it was down to the power steering fluid (or lack thereof), the pump was running dry
Old 12-10-04, 03:08 AM
lex400sc
lex400sc's Avatar
Hey thanks for the tip aerostar.
You guys with the low fluid, did you find any leaks in your power steering system? How is your original psp holding up now? In other words, is this a precursor to a bigger problem?
Old 12-10-04, 04:22 AM
jeremyp111
jeremyp111's Avatar
My PS pump is fine. I have a very slow leak where the rubber hose connects to the bottom of the reservoir. I need to replace the hose and clamp.
Old 12-10-04, 09:24 AM
rscott
rscott's Avatar
im missing a small chunk from my rubber hose. the actual leak is just a small crack but the missing rubber part of the hose doesnt help. i need to replace the hose too but lexus charges a ridiculous amount. I tried a supra hose but it comes up short barely. you might be able to get it on but i decided against it.
Old 12-10-04, 05:56 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
The seal on my PS pump was gona plus the hose between the resevoir and pump was cracked
lexman52
02-03-16 03:17 PM
fliaznguy
01-26-15 09:28 AM
spurge
SC- 1st Gen (1992-2000)
01-20-14 10:52 AM
KoSC300
02-25-07 06:14 PM
Seminole GS300
GS - 1st Gen (1993-1997)
07-21-03 01:38 PM
Quick Reply: HELP: loud wheezing sound under the hood!!!
