Car won't start, loud ticking noise under hood
Old 12-11-04, 05:54 PM
2ndchance
2ndchance's Avatar
Unhappy Car won't start, loud ticking noise under hood
So, I was getting ready to leave for the gym today, went to start my car, and no go. I get this loud, fast paced ticking noise from under the hood. The battery seems fine as everything that lights up looked normal. Don't know if its related, but it probably is: my stereo started popping fuses a couple months ago if I cranked it. Not just breaking them-they would blow out through the side. Then, about a week ago, my stereo speakers cut out with the radio still activated, and I got this horrible sulfur smell. Was going to take it to an electrical shop soon, but it looks like it has become just a bit more urgent.
Suggestions on what to look for? Please? I hate being without my baby for ANY length of time....
Old 12-11-04, 07:10 PM
abboushi
abboushi's Avatar
sounds like a starter, if it clicks when you turn the key and it doesn't turn over, thats my guess. search the symptoms of a bad starter and see what you find.
-Rashed
Old 12-11-04, 07:23 PM
indelible
indelible's Avatar
In my experience, fast clicking was due to a low battery. If it's a bad starter, theres no clicking, the car just wont turn over and just makes faint low buzzing sound.
Old 12-11-04, 07:25 PM
jeremyp111
jeremyp111's Avatar
You definitely have some electrical issues. It sounds like you have a short somewhere and it drained the battery down. Most of the time when you get the fast ticking but no turnover it's because the battery is too low to turn the engine over. Try and jump start it and bring it into an electrical shop to find the issue. Good luck.
J
Old 12-11-04, 08:47 PM
Carib
Carib's Avatar
Default Clicking...
I had the same problem as I too was getting the clicking when I tried to start.
It was intermittent and and eninge seemed to be straining to turn over when it finally did.
In my case, it was a bad connection to the negative battery terminal. The actual clamp was not tight enough.
Old 12-11-04, 09:15 PM
/Aerostar\
/Aerostar\'s Avatar
STARTER CONTACTS
Search it up
But first check the battery terminals
Old 12-12-04, 11:10 AM
mteele
mteele's Avatar
I had the same problem earlier this week. I dropped in a new battery, and that solved my problem
Old 12-12-04, 01:09 PM
2ndchance
2ndchance's Avatar
You guys are great, honestly. Checked the battery and a 12 V is putting out 10.44 V...probably the problem. Stereo's probably a different issue, though, eh?
Old 12-12-04, 08:04 PM
rscott
rscott's Avatar
is your stereo OEM or aftermarket?
Old 12-14-04, 04:47 AM
2ndchance
2ndchance's Avatar
Mostly OEM. One of my front door speakers popped awhile back, so now I have a set of JL Audio up front.
Old 12-14-04, 09:26 AM
indypwr
indypwr's Avatar
Post
i've bn having this problem for about 2 weeks now and luckily, it didnt happen during the meet at pathfinder park.........hehhe.....
well, im using the yellow optima battery and i've had it for about 4 yrs now.........u guys think it's time to change it? after the meet, i went straight to carson toyota and purchased the contact points for the starter just in case it's a starter problem and eventually save me $$$ fr buying a new one.
stillfly45
06-10-13 04:09 PM
djrazr
04-19-12 10:45 PM
xtremex626
14
02-16-12 11:09 AM
99GS Boi
Performance
07-25-09 09:02 PM
tobal
06-08-05 02:19 PM
Quick Reply: Car won't start, loud ticking noise under hood
