power steering question (whine, fluid, etc?)
Hi everyone.
On my drive from Chicago to New York, I noticed that my SC300 was making a whining noise. I determined that the noise was coming from the power steering. It must have happened as I entered Pennsylvania, and unfortunately being in the middle of nowhere, I had to continue driving. When I noticed the noise though, I bought some STP power steering fluid and added just a bit to top off. The noise seemed to quiet down after that point for about two hours.
I remember when I went for my last oil change, the guy made an off-hand comment about how the fluid was dirty. I was in a rush, so I just completely forgot about it.
I've searched through several threads, but I'm not sure what I need to do to fix this. There is a whining noise. The power steering still works. There is NO clicking noise. The whining noise seems to correspond to the engine speed (rpm) and kind of disappear when I push in the clutch. There is NO fluid gushing out of the reservoir. When I opened the cap, I noticed that the fluid was kind of bubbly or foamy. After a few seconds of cooling down, the fluid returned back to normal.
Anyone have any idea what problem I have?
Thanks,
-Brian.
Thanks,
-Brian.
I am looking more for what the problem is. Is it something that can be fixed by flushing the fluid?
Also, what does this have to do with engines and transmissions?
Thanks Nomis,
What do you think I should do first? Is it worth getting it serviced by the dealer or is it simple enough to do it myself?
They are quoting $100 for the power steering fluid flush.
What does the foamy power steering fluid mean? When the car has a chance to cool down, it doesn't make the noise when it's driven. After driving a few minutes at highway speeds, it starts to make the noise again.
Thanks,
-Brian.
Thanks,
-Brian.
Thanks Nomis,
Thanks,
-Brian.
Thanks,
-Brian.
A friend of mine flushed out the power steering fluid. It was a nasty, thick black. In any case, it seemed simple, although I'm sure the whole procedure was more difficult than it looked. Flushed it out and put in Mobil 1 synthetic ATF fluid in there. No more noise, and everything seems good.
-Brian.
-Brian.
Wait wait wait...he put ATF as in Automatic Transmission Fluid into your power steering pump??? I'm not sure if the viscosties are the same or not but unless your friend really knows what he's doing, you might wanna rethink that. Anyone else hav input...?
James
James
James
James
my question is does it matter the type of DEXTRON ATF you use and or synthetic or not. the cap says dextron atf type. but i have read toyota type atf is good to use and also i've read mobile 1 atf synthetic. also i have seen on bottles of dextron atf dextron mercon III and i have read dextron II is the best to use. can this be cleared up what type is the best to use??? dextron III , dextron II, synthetic or non. or just get the toyota atf(red/pink stuff) thanks
bought toyota atf to be safe. but the damn pump is still squeeking. so i guess i have to buy a new ps pump. changed the serpentine belt, and flushed the ps system i even took the whole pump apart cleaned inside. my tensioner has alot of resistance so i don't think its the problem. i am tired so tomorrow i am going to remove the belt to see if something feels like it is sticking. ex: alternator or water pump, ac. the noise is definitley comming from the ps pump but it spins fine and the new belt looks to be getting wear already? trying to save money.. ijust need the car to run till like december then i can swap the motor...
Stroock639
03-31-15 07:55 PM
trips1
RX - 1st Gen (1999-2003)
09-13-09 07:15 AM
