Car Wont Start !!??
Car Wont Start !!??
So I have a new battery, checked the Main fuse and actually removed, checked and plugged every fuse back in. All seems ok but this is whats happening:
I get dome light, door lights, and headlights work but nothing more.
It's like the key is not recognized or something. No radio, no power seats, no auto-tilting. If i turn the key to ACC nothing happens and definitely nothing when I try to crank. No clicking, nada.
I've found a similar thread and tried every suggestion but still no go.
https://www.clublexus.com/forums/sho...light=key+work
Anything else I can try ..... Thanks
Keeper of the light
if you followed my post #9 and did it correctly, i'd say buy a new starter. you'll know in an hour if it is locked down when your battery is dead again. Either way, it is probably still toast.
Wish I could help but I haven't run into such a problem before.
Did you check the fuses in your footwell also?
I know most of the important fuses are under the hood, but there are a few in the footwell.
Good luck.
~Alan
I'd say starter like everyone else but if NOTHING is turning on (radio, gauges, etc) then I'd point to the ignition switch. The car is acting as if there was no key in the ignition.
Try checking for power at the switch. If it's there, then the switch is bad. If not, check the fusible links under the hood. The THICK fuses that are like little bricks. Not the blade ones.
Good luck!
Good luck!
what model you got how many miles on it, i havent herd of any starter contacts having problems, starters yeah, but your not getting radio either right, i would guess a short in the starter, but make sure your key isnt messed up, does the lights dimm, can you cat leat get the car to crank>
Thank you all for your help. Unfortunately I wont really be able to work on it until this wkd due to work.
I too am thinking ignition switch, mainly cause i dont get anything when the key is inserted. No radio, no gauges, no tilting of the steering wheel.
Its a 97 sc300 with 110k. As far as the key itself, I only have 1 and its not the remote keyless one. It is the master as its the one ive been using all this time.
Again thanks for all your help.
Keeper of the light
Originally Posted by edgesc01
and yes I can turn the key all the way to the right. But nothing happens, no sounds, no click of anything and definitely no crank.
FYI, this is the same thing that can happen if you blow an ignition fuse. They should be under the hood and be very large. check the contacts on them and make sure they mate well.
Ooh if you have no radio and no cliking when you turn the key, then it has nothing to do with the starter. Chek the battery, especailly the negative battery terminal.
And skoldfc3s, yes the starter contacts are a problem, believe me, it has happened to me and many other people.
Former Sponsor
I am currently having the same problem and would like to know how edgesc01 resolved it.
I'm thinking that it is a big brick relay/fuse type thing. Twice now I have gotten lucky and pulled it (while also pulling out and re-insterting every plug on the grid) and put it back in... jumped in the car and gotten the doorlocks to work. Always before the doorlocks don't even work. The first time that I got it to work however, i had enough time to put the key in and crank it up... BUT all the interior lights and my radar detector were FLIPPING out... as in too much power juicing up the lights too bright..
I've also noticed that when nothing is working, i can hit the door locks and it seems to trip (or click) something in a box that resides on top of the steering column up under the dash.
I will get around to testing and hopefully replacing the main ignition brick fuse under the hood and hopefully solve my problem... at least I think that this is IT... anyone have any reason to believe it isn't?
Keeper of the light
