bolt pattern on 1UZ and R154 bellhousing (SC400 auto to 5speed project)
#46
The 1UZ is much wider then the 2JZ, I wonder if there will be enough room for the master brake cylinder. I talked to Neil and stated that the LS would have difficulty fitting it in. However, SC400 is a different animal.
#47
If you hear any more information on this let me know as I would like to have everyone's input.
dennis
#48
Originally Posted by /Aerostar\
Sick project bro
If you need any help with this stuff I may know the answer, after this weekend I will have dropped my tranny 3 times in the last 4 weeks. Im so glad that a CL guy is finally doing this, it always seems that those crazy Austrailian guys only do this kind of stuff. Best of luck to you man ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
#49
Originally Posted by VSsc400
did you run into any difficulties while you were re-installing the transmission? There was another guy who had to drop his trans and he mentioned that it was somewhat difficult to get things re-aligned.... the shop manual makes it look faily easy to drop or re-install either one of the trannies.
Another thing, make sure the driveshaft center bearing carrier will bolt up to the body correctly, if not, you would either have to make a new mounting point for it or modify the DS
alright man, good luck, and if you need any more help just ask
PS. Once the tranny is in but there is still a gap (about 1/2" or less), you can insert some of the bellhousing bolts and slowly and evenly drive those in to force the tranny and engine together...works like a charm
#51
Lets see, my car is lowered 2inches, then I had the rear on rhinoramps (6"), then I jacked up the front and rested the frame on jackstands about 14" off the ground. I would say the whole frame was about 13-14" inches off the ground. But the more room the better, I was limited by my crappy $10 floor jack
#52
thanks man.
#53
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Awesome projects guys.
I just started too look into doing my sc4. I got a shop in town that does some freajy stuff with cars. They looked at it and basically if I can get the bellhousing and parts, they will work on the conversion. I have a liitle experience, did a Ford 302, 5 speed FI into a 83 280ZX. with stock hood. Complete sleeper. Now I am interested in doing this 5 speed. This is an awesome treat. Keep it alive.
good jobs guys
vaki2
good jobs guys
vaki2
#54
good jobs guys
vaki2
good jobs guys
vaki2
#55
awesome! just remember you will also need to get the tailshaft from an R154 out of a soarer TT otherwise as stated before your shifter location will be under the radio.
When you figure out the right configuration I'd love to find out exactly what parts you used and how much it would cost on parts and labor. Just the parts that are necessary to fit on the SC400 not like upgraded parts. If this ends up working, I'd consider this as an option for my SC. And you could probably save some of those costs by selling off the auto tranny and all odds and ends that you bought extra.
When I first got this car I wanted to get a manual fabbed but that's alotta cash. I'd much rather have a swap over fabrication because of the price and overall reliability (Toyota parts).
I'm truly a fan of this project.
#56
Originally Posted by DarchMage
So VS, this is definetly going to bolt up correctly?
I will post up once we are done with the conversion i will post up exactly what you need down to the bolt. We are going with "normal" parts and not using any upgraded parts (why spend more money when we don't even know if it's going to work?) I've never swapped out a trans but i'd rather own all the tools for the price of the labor and there is no better feeling than getting to know your car intimately.
Hopefully we will recover some money from selling whatever stuff we won't need. It sucks because by the time we are going to have a lot of parts left over. The best we can do now is to make sure that everything has a label so we know exactly what car they go on when it comes to sell them.
#59
with the custom bellhousing, R154(any) tranny, and tailshaft from a soarer TT should put it in the correct location.
I'm not mechanically inclined but I'm sure it'd be a large step up if I got a repair guide to help me out with this project.
#60
So is this why you were looking for an alternate repair guide a little while back? Because of this project?
I would think you would need the manuals since they tell you the proper torque values for the bolts when re-installing all the parts.
