ATTN: 5-speed guys with loose/notchy shifts...
Old 02-03-09, 12:44 PM
  #121
Ryeno
Banned
Ryeno's Avatar
I have a question. when you put the green thing into the tranny do you line it up like a + or a X shape? I put it in as a +.
Old 02-03-09, 01:48 PM
  #122
craaaazzy
craaaazzy's Avatar
Originally Posted by jgdynamics
btw, i think someone on supramania made a shortshifter for our transmissions... he made it for his mk3 supra... which i believe has the same transmission.
what i've seen mkiii people doing is removing the dampener piece of the shifter, shortening the throw a little bit. it works and ur shifter will sit lower as well but you will need to buy a new **** since there are no threads on shifter now.
Old 03-05-09, 08:10 PM
  #123
blacknblue
blacknblue's Avatar
Just did this on mine, took about an hour but the shifting feels amazing.
Old 03-05-09, 08:13 PM
  #124
5sp_jzz30
5sp_jzz30's Avatar
if you would have searched you would see another option. Marlin Crawler solid poly-plastic insert. better then the "green" seat. period.
Old 03-05-09, 10:50 PM
  #125
blacknblue
blacknblue's Avatar
Yea I saw that, it probably is better, however I needed it by this weekend. But thank you sir.
Old 06-08-09, 11:52 AM
  #126
xzeus
xzeus's Avatar
I was just wondering also, if it does matter if its + or X? will it make shifting any different
Old 06-08-09, 12:15 PM
  #127
craaaazzy
craaaazzy's Avatar
i don't remember my part having a + or an x (since i bought mine from marlin crawler). but it did have a grove that was needed to install/go underneath the 2 horizontal knubs...so i would say +.
Old 06-08-09, 01:07 PM
  #128
CleanSC
CleanSC's Avatar
Originally Posted by CleanSC
Aero:
Nice and tight after I put the seat in. w00t.
Over 4 years later I had the shifter out replacing my clutch and the bushing was pretty chewed up. I have only daily driven it 2 of the past 4 years.
These things don't last. Maybe 3 years depending on your style. Check 'em every few years.
Someone should machine these out of Delrin or nylon.
EDIT: Someone does. Look at that.
Old 06-09-09, 08:31 PM
  #129
speed6
speed6's Avatar
not to burst bubbles, ive been doing this mod and telling everyone for at least 10 years and i have done it on r154's
Old 07-29-09, 10:16 PM
  #130
TroySC300
TroySC300's Avatar
Just found this thread, bumping it to the top for 5spd noobs like me
Old 08-02-09, 01:39 PM
  #131
7armani
7armani's Avatar
I just bought the green and white bushing from Toyota of Dallas yesterday.
Green shifter seat - 33505-35020 @ $12.12
White shifter bushing - 33548-31010 @ $5.14
Just finished replacing the parts on my 92 SC300. The white bushing is easy to identify as mine is still in good condition but difficult to remove. The Green seat is gone and seperated from the black rubber. And remember to remove the old rubber before installing the green seat. I topped up the grear oil from the hole. Cleaned the shifter spring and greased them. Lastly I padded some powder on the rubber boot before putting everything back in order. The result is WOW. So crispy and tight. I highly recommend all 5 speed owner to try this. Thanks CL and all who had contributed to the site.
Old 03-01-10, 12:40 AM
  #132
RjBLayz
RjBLayz's Avatar
I will have to try this.......
Old 03-01-10, 02:53 PM
  #133
6SOARER
6SOARER's Avatar
Thanks for bumping this oldie but goodie. I been searching for those part numbers for the longest time..
Old 12-30-10, 04:17 PM
  #134
4thHorsemn
4thHorsemn's Avatar
Originally Posted by deruvian
The shifter setup in the models with the W58 (1995+) is totally different. I haven't tried to replace the part in question on my '95, but I have seen the shifter assembly and it doesn't seem that this applies to the W58.
Like a complete idiot, I didn't read the ENTIRE thread........ it wasn't until like page 5 that they mention the trannies are different.... I was questioning my mechanic skills when I couldn't just lift the shifter out of place when all the bolts were removed.... HAD I JUST KEPT READING!!!!!! DAMMIT! WASTE OF TIME AND MONEY! IF YOU HAVE A 95 + W58 THIS WILL NOT WORK!!!!!!!
Old 12-30-10, 07:28 PM
  #135
ashtray
ashtray's Avatar
So how do us 95+ W58s fix nasty shifters?
Quick Reply: ATTN: 5-speed guys with loose/notchy shifts...
