1JZ swap (general questions)
#46
From what I know u can use a 7mgte turbo tranny all u would need is the 1jz bell housing. They have the exact same gear ratios. but I think it will only work if your putting it in the older supras
#48
Originally Posted by Kstyle55
true we will be at the supra meet in melborne this weekend with alot of cars from the shop supras and Sc300 with either 1jz or 2jz swaps and we are located in the Ft Lauderdale area
Im well aware of that.. Im one of the guys who helped set it up and all.. I was supposed to fly down this weekend to go but I cant so my fiancee will be taking out my car for me since I left it in FL
#50
Mortgage Slave
Originally Posted by indypwr
can you use stock auto tranny from sc300 with the 1jzgte?
If your SC300 is fitted up with an A340E auto tranny (check the VIN plates) then yes it will bolt up. I've got the A340E tranny on mine, just remember if you're planning for anything more than 200 or so rwkw you should look at getting an ATF cooler and a shift kit for the auto.
Jose
#51
i have the soarer motor with the R154 tranny ...but am comming up dead on the wiring info on soarer to SC300 info.....can anyone help? It seems as many are quiet about the wiring....which i think is a load.
#52
#53
Originally Posted by JZZ30TT
1J is a nice flowing head? since when? Anyways, yea stock turbos suck... mine are pretty much blown running 14psi, fmic, and turbo back exhaust. ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Gibenstein
Performance & Maintenance
03-22-05 06:32 PM
