DIY: Converting cornering lights into fog lights
Old 05-17-10, 10:16 AM
Sohconthis
Sohconthis's Avatar
any pics for this diy yet?
Old 05-17-10, 10:38 AM
SC_coupe
SC_coupe's Avatar
Thanks for bringing this post up, didn't know it existed. I've got the 95-96 look going on except my fogs are still cornering lamps. Plan to attack this project soon!
Old 05-17-10, 10:42 AM
turbodremz
turbodremz's Avatar
just retrofit if you want HID's..trust me you will be much happier
**crappy cell phone pic**
Old 05-17-10, 08:35 PM
Sohconthis
Sohconthis's Avatar
i would but i dont like the non oem fit of the retrofits....
Old 07-03-10, 10:27 AM
Kyle1JZ
Registered User
Kyle1JZ's Avatar
just wondering if there is pictures for this diy yet
Old 07-03-10, 02:10 PM
turbodremz
turbodremz's Avatar
you cant even tell I have done a retrofit on my lights until they are on and the light is emitted in the proper direction.
Old 07-03-10, 11:58 PM
Sohconthis
Sohconthis's Avatar
hmmm....daytime pics?
Old 07-04-10, 09:29 AM
turbodremz
turbodremz's Avatar
Ill see if I can get some today while im putting my mid-pipe on.
Old 07-04-10, 09:38 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I think OLT copied and pasted this old thread and subject write off of www.intellexiual.net. Did you?
Just kidding. It looks like the same wirte up as I used when I did mine, and then everyone gave me crap about on here about doing the mod. Due to them not OFFICIALLY being fog lights, but simply being turn signal indicators.
Be aware, if you do this mod, DO NOT use anything brighter than a 27 watt 1156 style bulb, in this factory housing. It will melt the housing! I put in a 55watt, and it lasted about a month or so. I noticed the color inside the housing was started to turn a little brown. So be aware! I know from experience. If you use an LED, I am unaware of the brightest you can use. You may experience something different. JMO.
Old 07-05-10, 06:12 AM
PowerLINK
PowerLINK's Avatar
Default i had this mod done for over 7 months
all i did is rewire the turning light to the city lights and i was done havent had a problem ever since
Old 07-05-10, 01:03 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
It looks good! How do you do that?
Old 08-25-10, 06:59 PM
joselpc84
joselpc84's Avatar
This is nice. But what about beam direction?. You may do the convertion but these lights won't aim straight still, this won't happen on 95+ fogs. Perhaps this is why some prefer to retrofit.
Old 08-25-10, 11:07 PM
saiko2j
saiko2j's Avatar
http://www.facebook.com/photo.php?pi...f&id=501467790
heres mine!
Old 01-24-11, 12:58 PM
JayCaz
JayCaz's Avatar
Hello O.L.T.
Old post but pretty sure some people are still doing or planning on doing this conversion like myself.
Been doing some searches, planning things out, getting needed things, and today had an idea and I thought I would draw it up real quick and post it to see if this is possible and if it would work. So what do you think or what does anyone else thinks about this working? And what amp fuse should I use?
Paint pic is just to sum it up a bit
And other pic is how I will be wiring it(its only taped for pic purpose) red tip to low-beam power, black tip to ground on frame.
Splicing into the positive wires from each side of the low beams to the power wire of the male adapter into the H3 housing, and grounding the male adapter's ground cable.
Attached Thumbnails DIY: Converting cornering lights into fog lights-h3-conversion.png   DIY: Converting cornering lights into fog lights-dscn1193.jpg
Old 01-24-11, 08:42 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I am not sure who did the conversion for rich and gave him the info, but it was surely before 2003 so if someone else does it, add to this thread and email rich for the update so he can add it into the faq. Just be sure to host your images in the cl gallery as rich's FAQ is for permanent info.
Quick Reply: DIY: Converting cornering lights into fog lights
