sc250 what do i need to make it happen?
Whats up club Lexus. I need alot of info. Let me start by explaining. I am planning on doing a 1jze swap into a lexus sc300. I’m still shopping around for a broken down sc. What do I need to do the swap?
Do the automatic tranny mounts bolt up to the jdm 5-speed?
Does the ecu plug right in?
Does the Drive shaft bolt right up to the sc diff?
Is there a difference between the sc300 and 400 diff?
Do the diffs come with LSD?
Whats kind of other advice do yall have for me?
Thank you Club Lexus
Everything bolts up, ECU is pretty much plug and play except for a few things like the gauge cluster (it will work though). You'd be better off buying a whole 1jz front clip to make sure your not missing anything.. My rear end has lsd but I think its the one from the soarer
The Mk3 clip wont fit because of the oil pan. What about the aristo or chaser clip? Does anybody know if there are any clearance issues with the oil pans or something other.
