headers from Tundra on 1UZ?
Old 01-27-05, 02:24 PM
JTJerryls400
JTJerryls400's Avatar
Default headers from Tundra on 1UZ?
can we use headers form tundra on our uz1 fe?
there is link:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33631
if yes that will be great
thanks
Jerry
Old 01-27-05, 11:04 PM
chrisman
chrisman's Avatar
hi, those are the headers i used on the twin turbo sc400.. i did have to change 1 of the 8 header tubes, and i cut the collector off..but they did fit between the frame rails..
also, i turned them aroud--faced the outlets firward for the tubos..
i didnt try checking to see if they fit facing rearward--but guessing, id say yes there is a chance they would fit, but you will also need to change some things-like i did..
Old 01-27-05, 11:42 PM
JTJerryls400
do you have turbos on front (near radiator) or under engine?
Maybe small turbos (T25 or t28) will fit under engine but high enough no need use electric pump for oil return...?
Old 01-28-05, 07:25 AM
chrisman
chrisman's Avatar
hi, i mounted the turbos (2 toyota ct26s) in front of engine-up high.. theres a long thread in the Forced Induction forum around here.. its called "another twin turbo".. but heres a pic..
Old 01-28-05, 07:45 AM
JTJerryls400
thanks
I had supra mk3 in the past so must say that turbos are huge compare to how they flow. But if use something not so big say t25 or t28 it can fit under engine. (now in dsm I have fp28g big- outside it is as small as normal 25 but support almost two times hp's as regular t25..
Saw setup (turbos under engine) in internet but pics are so small...
http://www.mechtech-ms.com/html/turbo.html
Nobody have bette pics that setup (how they fit turbos under engine)???
Your setup looks v. good.
how you reverese that tundra headers (left to right?) or upside down?
thanks
Jerry
edit: how much do you pay for that headers?
Old 01-28-05, 09:18 AM
chrisman
chrisman's Avatar
i switched them--left to right and right to left..thats so the outlets faced forward..
mitmaks
12-29-16 05:03 AM
oldManTan
05-20-16 02:31 PM
SRV1
13
03-23-10 02:55 PM
powmax
08-01-07 11:38 AM
tuninghaus
12-05-06 03:36 PM
Quick Reply: headers from Tundra on 1UZ?
