List of members with 1JZ swap
#106
Damn i guess i never got in on this!
1jz
Slowmotion built 4 inch mid to 3 inch duals
Driftmotion pullys
Clutch Fan delete
AC DELETE
Stanza E fans
HKS Pod filter
Greddy Profec B spec 2
DriftMotion intercooler
Home brew intercooler piping
Greddy Type R bov
DR TWEAK patch harness
AEM EMS 30-1100
spec stage 3+
w58
15lbs i put down 365 stock one a stock downpipe!!!
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/IMG_2250.jpg)
1jz
Driftmotion pullys
Clutch Fan delete
AC DELETE
Stanza E fans
HKS Pod filter
Greddy Type R bov
AEM EMS 30-1100
spec stage 3+
w58
![](http://i18.photobucket.com/albums/b107/2zumeunos/SC300/12-13-08/IMG_2352.jpg)
#109
it goes through the fender there like oem, first pipe is a 45'. second is a long 90'. next is the stock plastic pipe that's normally there, from there its a straight piece to a 45' silicone connector to a long 90' again and that's at the inter cooler.
it looks kinda janky but it works and its only temporary till i go single turbo.
![](http://i18.photobucket.com/albums/b107/2zumeunos/SC300/IMG_2346.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/SC300/IMG_2347.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/SC300/IMG_2349.jpg)
#113
![](http://memimage.cardomain.com/member_images/6/web/3006000-3006999/3006934_99_full.jpg)
updated pic.
Apex Power FC ECU
FC Datalogit
740cc injectors
Aeromotive FPR
Custom Catch can
Custom Power steering reservoir and bracket
Titan fuel rail
MK3 resistor pack
KU engineering intake manifold
90mm throttle body
2JZ machined cams
Cam Gears
SS manifold
HKS BOV
Turbo blanket
Custom Radiator brackets
Greddy T78
Aluminum pulleys
SS Downpipe
Greddy timing belt
Aluminum Coil cover
Haste 4 row Radiator
silicone radiator hoses
Flex-a-lite fans
Optima battery
Stainless custom centered exhaust.
4" and 3" aluminum I/C piping
Custom throttle cable
FMIC
60mm Wastgate
relocated battery and fuse box to pass'r side
Drivetrain:
IPT transmission modified vavle body
IPT Raybestos Blue perfornance clutches and plates
IPT modified torque converter
Suprastick V4 transmission controller with paddle shifter
Supra TT LSD (coming soon)
#115
1991 Toyota Soarer
1jzgte Auto
intercooler kit,
Turbosmart BOV
Turbosmart Boostcontroller
4inch Down Pipe
3inch Downpipe back exhaust (ApexII tip)
I dont know how much power 330hp or not far from it
![](http://i151.photobucket.com/albums/s145/turbo6967/DSCF1534.jpg)
New motor swap in process
2jzgte with new R154 Tranny
intercooler kit,
Turbosmart BOV
4inch Down Pipe
3inch Downpipe back exhaust (ApexII tip) (Doing a Dual Tip this spring)
End of Summer Goals (67mm single turbo @ 22psi)
1jzgte Auto
intercooler kit,
Turbosmart BOV
4inch Down Pipe
intercooler kit,
Turbosmart BOV
4inch Down Pipe
#116
updated pic.
Apex Power FC ECU
FC Datalogit
740cc injectors
Aeromotive FPR
Custom Catch can
Titan fuel rail
MK3 resistor pack
90mm throttle body
2JZ machined cams
Cam Gears
SS manifold
HKS BOV
Turbo blanket
Greddy T78
Aluminum pulleys
SS Downpipe
Greddy timing belt
Aluminum Coil cover
Flex-a-lite fans
Optima battery
FMIC
60mm Wastgate
Drivetrain:
#118
I've got a 95 5-spd Black SC3, with a 1JZ sitting next to it.
Starting on gaskets and overhaul bits then replacing the head tomorrow before I drop the 1JZ in but so far it's on stock twins with 272s, springs, and a 3-angle valve job.
Other than that it's a 100% stock boost, stock intake, stock side mount, stock exhaust, all bolted onto a 185k mile old W58, and tuned on an HKS Fcon V. Budget ftw.
