List of members with 1JZ swap
#122
Just realized I should add some pixorz!
Here is mine as of now.
-1JZ
-3" full exhaust
-K&N filter
-Apex-i AFC-Neo
-AEM Uego
-Fleabay FMIC and piping
-Greddy Profec B-II
-JDM tyte silver painted caps.
Edit: Videos too!
http://videos.streetfire.net/video/1...300_172422.htm
http://videos.streetfire.net/video/1...t-2_195588.htm
-1JZ
-3" full exhaust
-K&N filter
-Apex-i AFC-Neo
-AEM Uego
-Greddy Profec B-II
Edit: Videos too!
#124
Realized never added mine to the list
1jz w/Stock Twins
14 psi
GreddyFMIC
Turbo Smart BCC
Greddy SCC
SAFC NEO
Megan Coilovers
LS400 BBK (on garage floor)
Dyno: 268hp/279tq
3" dp split to 2.5 out
Waiting to be installed
TRD LSD installed
Single PTE6262: Soon, not ready to give up the quick spool of the twins.
550cc injectors (in the garage)
Stocked Pile parts in the garage T4 Manifold/46mm WG (Thank You) Driftmotion.
Happy if I get 400 RWHP.
My Ride
My Engine Bay
1jz w/Stock Twins
14 psi
GreddyFMIC
Turbo Smart BCC
Greddy SCC
SAFC NEO
Megan Coilovers
Dyno: 268hp/279tq
TRD LSD installed
My Ride
My Engine Bay
#126
i am new lexus, im working on my sc 300, 2jzgte block with 2jz head and r154 . ihave 2jzgt ecu and harness from auto aristo. any one help if at ecu will work with 5speed? also need halp with wering? thanks
#127
try this one
https://www.clublexus.com/forums/per...-its-here.html
Click on the search botton on the top and type "2JZGTE swap" and see what happen
https://www.clublexus.com/forums/per...nce-issue.html
https://www.clublexus.com/forums/per...-concerns.html
https://www.clublexus.com/forums/per...-question.html
GL
#130
Here is my list.
93 SC 300
1JZ/R154 soarer
Soarer a/t ecu
DR TWEAK patch harness
Piggyback Map ecu
Wideband
Single turbo
Xs manifold
60mm Wastegate
HKS EVC IV
HKS SSQV
HKS intercooler piping
Stock Soarer intercooler.
Custom 3" dp
Custom 3" no cats
Custom 3" y pipe to 4" outlet mufflers
ACT extreme pp 6puck unsprung
Walbro pump
Clutch Fan delete
Electric fans
Silicone radiator hoses
LS400 BBK
93 SC 300
1JZ/R154 soarer
Soarer a/t ecu
Piggyback Map ecu
Wideband
Single turbo
Xs manifold
60mm Wastegate
HKS EVC IV
HKS SSQV
Custom 3" dp
Custom 3" no cats
Walbro pump
Clutch Fan delete
Electric fans
LS400 BBK
#133
auto 1jz(non vvti)
hks hard pipes
3" down pipe
apexi afc
greddy fuel cut defenser
soarer SMIC
impressions: love the new power, motor is so smooth, you can barely hear it when it's idling, the car is a sleeper
hks hard pipes
3" down pipe
apexi afc
soarer SMIC
