I have Qs about 2jzgte swap from Toyota Aritso will a usdm ecu work with jdm clips?
Old 02-05-05, 01:47 PM
Five1OH
Five1OH's Avatar
Default I have Qs about 2jzgte swap from Toyota Aritso will a usdm ecu work with jdm clips?
I have been researching the 2jzgte swap and jarco sells Toyota Aristo 2jzgte automatic clips for pretty cheap ($3695). If I were to swap the 2jzgte into a 5 speed sc300, will the auto ECU work, or will I need a manual tranny ECU? if yes, will a ECU from a usdm 6-speed supra work with a JDM 2jzgte?
Also, what other parts will I need to swap a JDM Toyota Aristo clip into a sc300.
For example, I heard that the JDM 2jzgte Toyota Aristo engine mounts and oil pan are different from a mkiv supra. What other parts from an Aristo are different that I will need to change?
Old 02-06-05, 12:31 AM
gowest
gowest's Avatar
It should work fine if you gonna mate 2JZ-GTE to your 5 speed tran, since auto tran come with seperate ECU. I mean 2Jz-GTE automatic clip should come with Engine ECU and Transmission ECU as well. I seen many 2JZ-GTE automatic with 5speed tran swap( by borrow 5speed from1JZ-GTE). This swap was done cause 2JZ-GTE is hard to find and very expensive. May be some trick have to be done, I find out later.
2nd question ... I think that US spec6speed and JDM 2JZ have different MAF and MAP sensor and don't think that it can work with each other. 320 hp and 280 hp rating.
3rd All oil pan are interchangable so don't worry just use your old oil pan. Aristo engine come with front- middle and rear oil pan, depend on what year being made. Some come with 4wd system as well.
Old 02-06-05, 12:43 AM
reamemiya
reamemiya's Avatar
https://www.clublexus.com/forums/sho...d.php?t=149852
this manual will have ALL the info you need about 2jz swaps
Old 02-06-05, 06:16 AM
philauldridge
philauldridge's Avatar
Default Aristo engine with US ECU
Yes! You will definitely want to get the US Supra ECU AND US harness. This will connect right up to your JDM engine with no problems. You may find you'll want to replace the air sensor with some brand of VPC or equivalent. The MANUAL ECU for the Supra and appropriate harness WILL mate right up to your stock 5-speed tranny.
You're on the right track!
tps3443
Performance
01-19-18 05:52 PM
cavette
05-03-09 07:33 PM
dbltakegs3
16
05-27-08 06:25 AM
dbltakegs3
SC400 / 300 Classifieds
02-13-08 08:59 AM
USAF_RT
07-22-07 05:23 PM
Quick Reply: I have Qs about 2jzgte swap from Toyota Aritso will a usdm ecu work with jdm clips?
