Kaaz LSD - Who has one
Old 02-21-05, 09:49 AM
bmatsu
bmatsu's Avatar
Default Kaaz LSD - Who has one
Hi everyone,
I am interested in getting a Kaaz LSD, and was wondering if anyone has one, and what kind of experience have you had with it.
I have done a search on this forum, but I am looking for first hand information, before I plunk down the $$$
Thanks for your comments and suggestions,
bmatsu
Old 02-21-05, 03:31 PM
Supermac7
Supermac7's Avatar
I don't have one. However, from what I know of them, they work well, but are a bit noisy.
Jameson
Old 02-22-05, 11:22 AM
qtb33
qtb33's Avatar
I don't personally own one but my buddy with a S13 240sx has the Kaaz 2 way. I have driven the car both on the street and on the track.
My thoughts. They are alittle loud but his car is completly stripped so that may add to the noise. I think the 2 way isn't a good diff. if your just learning performance driving as the rear end will step out under drop throttle very quickly. What I'm getting at is if you under speed or over speed into a corner and try to correct with too much throttle over steer comes in a hurry.
I think a 1.5 way would be a good pick if your a novice driver. But in either case they are both clutch type and require lots of up keep. My buddy changes he rear end gear lube with his oil under normal driving and alway after a Drifting Event, HPDE or Auto-X.
But they are of high quality and if you have no problems changing the diff lube then
Old 02-24-05, 09:31 AM
hello1
hello1's Avatar
hello, i have one. its the kaaz 2way for the supra. its a little noisy, however i am used to clutch type differentials so if you are not familiar with them, they will be really noisy to you. good luck and its well worth the money.
Old 02-24-05, 09:47 AM
CP_Ree
CP_Ree's Avatar
I guess I'm still new to this Supra/SC interchangeable ordeal, but are you guys saying the Kaaz LSD will work in a SC300/400 rear end? Sorry if it sounds very newb-ish.
Old 02-24-05, 09:51 AM
hello1
hello1's Avatar
np. the kaaz 2 way for the supra and sc300 are the same part number. dat-3020 and yes i believe the sc300 and supra differentials are interchangeable.
Lex*Toy
Performance
23
09-30-07 09:08 PM
amy011079
IS - 1st Gen (2001-2005)
36
06-11-07 04:02 PM
D-MAN63
06-25-06 12:04 PM
laxdude362
01-12-05 09:38 PM
redgs4
Performance
12
03-04-03 09:29 AM
Quick Reply: Kaaz LSD - Who has one
