soarer 1jzgte swap guide
Old 04-24-05, 07:52 PM
  #46
BLK13X
Mortgage Slave
BLK13X's Avatar
Originally Posted by Bean
from what i'm reading, you need the 1jz ECU and harness as well, you dont use the 2jz stuff... in fact i think thats not possible since the 1jz uses speed density metering vs the 2jz-ge's Karman Vortex
What a lot of guys that do the A340E~R154 conversion do (at least for a little while) is run the factory 1JZ auto ECU (the manul still functions with it, no one's had problems with it). The only thing I see not working is the dash to ECU (JDM dash everyone knows about).
Jose
Old 04-25-05, 05:51 AM
  #47
SCdrifter
SCdrifter's Avatar
ill have to look ill post back after work
Old 04-27-05, 05:06 AM
  #48
SCdrifter
SCdrifter's Avatar
im sorry guys its been really busy at work and honestly i forgot last night.sorry again
Old 04-27-05, 09:37 AM
  #49
vududoc
vududoc's Avatar
yeah sorry for not posting either right now slammed in getting ready for a car show. ill try and track down tach issue.
Old 04-27-05, 11:59 AM
  #50
aasc300
aasc300's Avatar
Are there any driveshaft/mount differences putting an auto 1jz into an auto sc3?
Old 04-27-05, 12:53 PM
  #51
Bean
Bean's Avatar
Jose
how would the dash to ecu plugs not work? they are supposed to be plug and play...
now granted some of the sensors might be different and the instrument box computer might not know how to interpret the signals... but most of it should work
Old 04-27-05, 01:35 PM
  #52
vududoc
vududoc's Avatar
more reffering to signals....from what i gather his post read
Old 04-29-05, 02:35 PM
  #53
reamemiya
reamemiya's Avatar
will the 1jz bolt up to the stock auto sc300 tranny?
Old 04-30-05, 12:40 AM
  #54
Bean
Bean's Avatar
I believe so, yes... but the stock auto is even more fragile than the stock 5-speed
Old 04-30-05, 05:21 AM
  #55
2.5tsoarer
2.5tsoarer's Avatar
[QUOTE=Bean fragile [/QUOTE]
"Fra-Gee-Le, must be french" a christmas story,lol
Old 04-30-05, 05:07 PM
  #56
Bean
Bean's Avatar
its actually: "must be italian"
Old 05-06-05, 01:03 AM
  #57
Gibenstein
Gibenstein's Avatar
Sry for bumping this thread but it seems to be the most informative on the R154 Tranny . I was reading that the 95+ came with r154 trannys so does that mean if you buy a 95+ you shouldnt run into the problem of bashing the tranny well or matching the bellhousing to the 1jz ?
Or
Does it just give you the hands up on having the r154 tranny and the rear end and all you need is the 1jz r154 bellhousing correct ? Or am I missing something. Thanks for any help
Old 05-06-05, 11:46 AM
  #58
Bean
Bean's Avatar
Or
No, no toyota vehicle in the united states ever came with the R154 except the 1987-1992 Toyota Supra Turbo.
The 95 SC chassis and above have a larger tranny tunnel. I don't think it matters though since its the shifter position that is causing people problems; not the tunnel being big enough.
Get an R154 tranny, then you need a 1jz flywheel, 7m clutch setup, and a 1jz R154 bellhousing (call an importer, they are available for JZA70 supras all day long).
You also need the supporting stuff; like a custom driveshaft, R154 slave cylinder, etc
Old 05-06-05, 09:17 PM
  #59
Gibenstein
Gibenstein's Avatar
Sry I was getting it confused a lil b/c I noticed that for some reason they offer short shifter for 95+ sc's but not anything below. So instinct said to me maybe it was a r154, my mistake sry.
Old 05-07-05, 12:54 AM
  #60
Bean
Bean's Avatar
hey no need for apologies bro; its info out there stated boldly for others too to read
Quick Reply: soarer 1jzgte swap guide
