300-400 fan/waterpump pulleys??
Old 03-14-05, 11:59 AM
Shellhouse
Shellhouse's Avatar
Default 300-400 fan/waterpump pulleys??
Are these the same part? I'm guessing not...
Old 03-14-05, 05:15 PM
awj
Bluegr*** Performance
awj's Avatar
fan bolts to pump through pulley.
Old 03-14-05, 05:20 PM
Shellhouse
Shellhouse's Avatar
Yeah, got that. I was wondering if the 300 and 400 water pump pulleys are the same part (or are interchangeable).
Old 03-14-05, 05:29 PM
Shellhouse
Shellhouse's Avatar
Also, if anyone has a V8 pulley, I could really use one..
Old 03-14-05, 06:42 PM
Nomis
Nomis's Avatar
V8's don't have a fan pully - it's a hydraulic pump that drives the fan.
Old 03-14-05, 08:25 PM
Shellhouse
Shellhouse's Avatar
Water pump pulley.
Old 03-14-05, 09:19 PM
awj
awj's Avatar
oops
Old 03-19-05, 07:54 AM
Shellhouse
Shellhouse's Avatar
According to my local dealer, they are the same part #. Could someone PLEASE verify this before I drive 700mi to pick up a car and find out the pulley don't work?
Old 03-19-05, 08:18 AM
Lextreme
Lextreme's Avatar
The 400 water pump is powered by the timing belt.
Old 03-19-05, 08:29 AM
Shellhouse
Shellhouse's Avatar
Now I'm confused.. If the fan is driven by a hydraulic pump and the waterpump is driven by the timing belt, why is there a pulley on the fan? Where does it connect, and is it the same as the SC300 waterpump/fan pulley?
Old 03-20-05, 10:53 PM
chrisman
chrisman's Avatar
the water pump on the sc400 is kinda hidden from view.. its under the plastic covers, and is driven by the cam belt.. it is not cogged, and is driven from the flat side of the cam belt..
the fan pulley? the sc400 has a hydraulic fan driven by an oil pump.. this can be seen from the front, as it is external..this is driven from the flat side of the accesory belt..
these are 2 different pulleys... i hope tha clears it up..
i dont know about the sc300 pulleys..
Old 03-21-05, 10:07 PM
Shellhouse
Shellhouse's Avatar
Thanks for the info. I'll have to look at some pics to see the part that drives the fan. The 300 is very simple... the waterpump is driven by the acc belt and the fan bolts to the pulley. I'm also wondering if the PS cooler on the 400 also cools the tranny fluid (in addition to the cooler in the radiator).
Old 03-21-05, 10:16 PM
Shellhouse
Shellhouse's Avatar
Eh, maybe the other side of the PS cooler is for the fan fluid (like blinker fluid?). What a bunch of unnecessary BS..
Old 03-21-05, 10:52 PM
chrisman
chrisman's Avatar
on the sc400, there is a fan fluid cooler, and a power steerng fluid cooler,.the trans cooler is in the rad..
remember, these cars were selling in the 40,000 range in the early 90s.. grade a,fancy deluxe..
wacoykc
SC- 1st Gen (1992-2000)
01-04-14 11:58 PM
bzebern
SC400 / 300 Classifieds
02-16-12 02:57 PM
ddrsquad
05-26-11 04:05 PM
Glen
06-10-09 02:45 PM
Shellhouse
13
05-20-05 09:12 AM
Quick Reply: 300-400 fan/waterpump pulleys??
