Problem after BFI build
Old 03-18-05, 06:47 AM
gnats
gnats's Avatar
Default Problem after BFI build(UPDATE CODE 31)
Yes, I searched with no luck.
Now here is my problem. I built the BFI along with replacing the power steering pump. I went to test drive the car and the check engine light was on and when I floor it when the rpms reach 1900-2000 it bogs and I about slam my face into the steering wheel.
To be as specific as possible I also cleaned the Mass air sensor and the throttle body and as much of the upper intake I could.
I know the torque converter is btw those rpms. Is there a vaccum line i missed. Please help me out. Thanks!
Old 03-18-05, 11:26 AM
SupraCoup3
SupraCoup3's Avatar
pull the code for the CEL, then let us know what it is.
Old 03-18-05, 11:53 AM
bmatsu
bmatsu's Avatar
Is your car a SC300 or 400.
If it is a 300 make sure the where the 3 metal vacume lines that connect directly into the TB are clear. I had the same problem because they were clog. There are 3 very small hole that go into the TB. I just sprayed some TB cleaner though the metal line to clean it up and my car runs just fine now.
Hope fully you did not damage the MAS when you cleaned it. I hear pros and cons about cleaning it.
If your car is a 400 I do not know much about them.
Hope this helps.
Old 03-18-05, 12:30 PM
gnats
gnats's Avatar
I have an SC400 and I am getting code 31 which is the mass air. So what the heck did I do wrong and is it fixable.
I found a thread on here were owners with hesitation problems (like me) sprayed the MAS with the specific cleaner and had no problems.
Please any help would be great.
Old 03-19-05, 06:41 PM
gnats
gnats's Avatar
Anyone, know what to do. I haven't had any luck searching to find out if it is ruined. please let me know.
Old 03-19-05, 06:52 PM
bean_8044
bean_8044's Avatar
Mass Air Flow sensors are extremely sensitive, especially to cleaning chemicals. Unfortunatly, the only way to troubleshoot is to either get a different one to test on your car, or take yours to another car. It could be a loose connector, but im sure you would have found that out by now. If you do decide to bring someone else's MAF over, be sure to clear your ECU codes before you try to pull them again
Old 03-21-05, 09:57 AM
gnats
gnats's Avatar
Anybody have the part # for the MAF? Thanks!
Old 03-21-05, 11:00 AM
teke52
teke52's Avatar
Default Maf
I don't have the part number...but I have a spare one that I can sell to you. Hit me with a PM if you're interested...I'm in NJ and can ship. Let me know.
Ham
06-24-19 07:44 AM
Shane7213
SC- 1st Gen (1992-2000)
10-09-12 02:27 PM
wallyman42
01-07-12 01:14 PM
ynvme
10-19-07 03:36 PM
Salil022
06-02-05 12:59 PM
Quick Reply: Problem after BFI build
