Seafoam experts, check in here.
Old 02-03-08, 12:53 AM
  #121
Belement
Belement's Avatar
did this tonite 1/3 in vaccum line, 1/3 gas , 1/3 crankcase and as it smoked i felt the engine become more responsive, and the engine now idles lower..... now i dont recommend that u do 2 oil changes but im a person that thinks if it is worth doing then its worth over doing and i got a jug of crappy oil and crappy oil filter. After running for 5-10mins i pulled the car back into the garage and did the oil change and WOW it was black, only had 2000 miles on that oil, then run the crappy oil for 10 miles and came back and changed it out with mobile 1 synthetic and another new oil filter, the oil was a dark carmel so again it cleaned more out. Car runs amazing with all the get up and go that i was missing, will be doing tune up next day off for even better results. well hope the info helps and happy seafoaming
Old 02-05-08, 02:42 PM
  #122
breakb
breakb's Avatar
http://www.youtube.com/watch?v=2hrasAYG42g
is that the right way to do it? or...whaT? idk. =/
Peace out
Old 02-06-08, 10:59 AM
  #123
breakb
breakb's Avatar
anyone? want to know cuz i want to seafoam mines, but don't want to kill it or anything...
Peace out
Old 02-06-08, 02:06 PM
  #124
rootaku
rootaku's Avatar
I've seafoam twice so far, really hard to mess up if you follow directions. I did it on a sc300 however. I actually recorded it too and I'll probably add a Visual SC300 version. but yeah, its so easy.
Old 02-07-08, 11:20 AM
  #125
VJZ
VJZ's Avatar
When I change my oil, I Seafoam. What I have done is run 1/4 can through my oil filler hole on top, 1/2 through the throttle body vacuum line, and then the rest through the gas tank. Let set in engine while off for 15 minutes, and then run for ten.
IMMEDIATELY after that I run a full bottle of Gunk engine flush through and let that run for 15 minutes. When I drain, I let it drain extensively and then fill with 10W30 FULL synthetic Castrol Syntec. Engine oil gets cleaner and cleaner with every Seafoam treatment and runs so smoothly. After this oil change I am buying new Denso spark plugs (All I have ever ran in my cars) and Toyota Cap/rotor/wires.
I'll be considering fuel filter replacement soon as well just for added protection.
I highly recommend my method as I have never had a problem with oil consumption or leaks after using Seafoam with this method.
Old 02-07-08, 10:09 PM
  #126
speed6
speed6's Avatar
hope im not thread jackin... i used the berryman 2 step fuel inejction kit, part number 4024. its the ****. doesnt clean the motor per say, but the Fi part is clean. install it to the vacuum line directly on the "Y" part iof the intake mani. instant difference
Old 02-08-08, 12:50 AM
  #127
Luke_in_SD
Luke_in_SD's Avatar
I just looked at the video, do you really have to drive fast afterwards??
Old 02-10-08, 06:56 PM
  #128
Luke_in_SD
Luke_in_SD's Avatar
do I have to replace the spark plugs if I add seafoam in the crankcase and vacuum lines?
Old 02-10-08, 07:26 PM
  #129
Touge
Touge's Avatar
Any sc300 video ?
Old 02-26-08, 11:37 PM
  #130
UDel
UDel's Avatar
Can you use seafoam to clean your throttle body instead of carb cleaner? Anybody have instructions or experiences using seafoam on a 2nd gen GS430? I am interested in trying this on my car as well as my moms 99 TL.
Old 02-26-08, 11:50 PM
  #131
breakb
breakb's Avatar
just supposed to find one of the vaccum lines and it should be all the same thing. ppl have different ways of doing it. but anyone of them shoudl be find. since all there cars seem to still run, lol. just youtube like seafoam.
Peace out
Old 02-27-08, 02:05 PM
  #132
Konnan101
Konnan101's Avatar
I did my new car a week ago and did 1/3 in the gas tank, drove it for a week, then did a 1/3 in the pcv line and a 1/3 in the crankcase...the car runs like new.
Old 02-27-08, 06:32 PM
  #133
sc300L
sc300L's Avatar
Theres lots of how to videos on youtube on Seafoam with Sc's and other cars. But I really want to do this sense I now my engine could use it but its incredibly annoying to change the spark plugs in my sc..(97 sc300 2jz Ge) and just put new ones in because cleaned engine bay and learned the hard way why hand washing is the way to go on the Sc's lol. But will you have to change oil and spark plugs if you mix it with your gas?? And can you feel a Difference thought the gas method?
Old 02-28-08, 03:09 AM
  #134
breakb
breakb's Avatar
if i was to throw it in my oil and stuff. then i would def change sparkplugs, cuz in case. yeah...still haven't done this because for one thing...i don't even know where all the oil filter and stuff is yet, lol. need to look for that oil filter still, haha.
Peace out
Old 03-01-08, 06:10 PM
  #135
Luke_in_SD
Luke_in_SD's Avatar
I don't see why you need to change the spark plugs. If you add seafoam to the gas, it will burn just like a fuel system cleaner. If anything the spark plugs will be cleaner. I just changed mine back in September to NGK Platiums, so I think they should still be good
Quick Reply: Seafoam experts, check in here.
