R154 tranny...soarer and supra mkIII the same?
Old 03-21-05, 03:00 AM
Sil.n.Ex
Sil.n.Ex's Avatar
Default R154 tranny...soarer and supra mkIII the same?
Just curious as the mk3 trannys are obviously alot easier to come by. Are there any differences to warrant trying to find the already hard to find soarer 5-speed tranny? Or is it just as simple as grabbing the R154 form any mk3 supra?
edit: I guess I should have elaborated, but I mean the jdm sc300 (naturally) but the usdm supra. Reason was that if the tranny ever breaks, it will cheap and easy to replace. These 5-speeds can hold some pretty damn good power upwards of ~700rwhp last I check
Old 03-21-05, 04:47 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
The R154, from what I've come to have learn, is the same throughout, it all comes down to the bellhousing etc. (obviously the Soarer one slips straight in, no mucking about).
Lemme know what you find, how common are they in the US? I've been having dreams of a manual Soarer recently (Don't really wanna sell mine for a manual... got my car as a present so it's worth way more to me than any amount of money).
Jose
Old 03-21-05, 05:37 AM
VSsc400
VSsc400's Avatar
bellhousing is different
tailshaft is different
Old 03-21-05, 11:46 AM
got_trd
got_trd's Avatar
I can tell you the automatic trannies for the 1jz supra and 1jz soarer arent the same ($600 later and an extra tranny in the garage) so I doubt the r154 trannies will be the same
Old 03-21-05, 10:23 PM
Shellhouse
Shellhouse's Avatar
If the tailshaft is different, will a Soarer driveshaft work w/ a Supra R154 w/ a Soarer 154 bellhousing (w/ a ......)? Basically, take a MKIII turbo trans and put the 1JZ bellhousing on. Will the Soarer driveshaft fit?
Old 03-21-05, 11:33 PM
vududoc
vududoc's Avatar
soarer yes
SC300 no
Supra MK3 turbo only yes
do wat i did and swap the front portion of the driveline out
Old 03-22-05, 07:31 PM
Sil.n.Ex
Sil.n.Ex's Avatar
This sucks! It seems that the r154 requires as much work and money to get working as going 6-speed. Keep the responses coming guys, this is good stuff that a newb in the future can search on .
Old 03-22-05, 07:37 PM
VSsc400
VSsc400's Avatar
R154 tranny should be about 200 bucks off anywhere
1JZ bellhousing I've seen it as low as 200 bucks
R154 soarer tailshaft I only saw once once which I bought.
i bought the following for $850 shipped.
R154 tranny from a soarer
MKIII tailshaft and shifter
soarer tailshaft and shifter
soarer clutch fork
soarer driveshaft
MKIII driveshaft
soarer tranny rear mount
MKIII tranny rear mount
soarer rear cross
MKIII rear cross
it's not as expensive as a getrag-6 swap. no way.
It's not easy to come by but they can be had new for less than the core getrag-6
Old 03-25-05, 02:51 PM
Arizona
Arizona's Avatar
soarer clutch fork
soarer driveshaft
MKIII driveshaft
soarer rear cross
MKIII rear cross
Where did you purchase these items? You buy them new from toyota? I was about to go get a MK3 r154 rear and trans, 1jz bellhousing. Then only the driveshaft would be an issue. I thought all I would have to do is alter the length seeing how im using all MK3 parts I wont need any soarer parts.
Old 03-26-05, 11:59 PM
lexcoupe
lexcoupe's Avatar
soarer clutch fork
soarer driveshaft
MKIII driveshaft
soarer rear cross
MKIII rear cross
Yes, please explain, I would like to know where you got these. I have been thinking of just swaping the r154 instead of my poor old w58. Any info would be nice.
Kevin
Old 03-27-05, 10:52 AM
VSsc400
VSsc400's Avatar
let's see..
R154 tranny should be about 200 bucks off anywhere - supraforums MKIII for sale section or on ebay.
1JZ bellhousing I've seen it as low as 200 bucks - supraforums MKIII for sale or 1JZ swap section or ebay. I've seen it in all 3 places
R154 soarer tailshaft I only saw once once which I bought. supraforums MKIII 1jz swap section.
i bought the following for $850 shipped. (this was a package deal a guy over at supraforums made me).
soarer clutch fork
soarer driveshaft
MKIII driveshaft
soarer rear cross
MKIII rear cross
you can get most of these parts and then some if you go to a front-cut vendors and they will be able to get you the whole thing for under $2000. Of course the stuff you don't need you are going to have to sell yourself because most vendors will not let you pick and choose only the parts you want.
Old 03-27-05, 04:58 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
let's see..
...you can get most of these parts and then some if you go to a front-cut vendors and they will be able to get you the whole thing for under $2000. Of course the stuff you don't need you are going to have to sell yourself because most vendors will not let you pick and choose only the parts you want.
WHAT THE!!!! $200 for the R154 tranny?!??!?!?! It'd probably be too heavy to ship to Australia though
Old 03-27-05, 07:23 PM
bean_8044
bean_8044's Avatar
Its less than 60kg which is the EMS limit i believe...
Old 03-27-05, 09:49 PM
Bean
Bean's Avatar
yeah R154 may be less than 60kg... it is a BEEFY tranny though... the V160 I think is over 60kg... only trannies I've seen as large are the 6-speed tranny that comes with the VQ35DE-Z variant and the Borg-Warner T56
But yeah... all the parts that just got listed can be bought out of local junkyards here or out of engine importers... venus auto is a great place to get one-off parts like that...
once you've got it all setup, its very economical too... blow a tranny? oh well, spend $200 more for one out of a junkyard...
as far as i know, all you need is the 1jz manual flywheel with the 1jz R154-variant bellhousing and you use 7m-gte clutches
Old 03-28-05, 12:58 AM
Sil.n.Ex
Sil.n.Ex's Avatar
Very informative posts here guys. Thanks for all the info.
Quick Reply: R154 tranny...soarer and supra mkIII the same?
