Dual in-tank fuel pump brackets
Old 03-21-05, 11:39 AM
SupraCoup3
SupraCoup3's Avatar
Default Dual in-tank fuel pump brackets
Hey guys,
I just spoke (well, emailed) Ryan Woon of WOTM about dual fuel pump brackets for our SCs, and this is the resonse I got...
It will [fit] but you have to cut the bracket just a bit to get it the right length downward
I've been searching for a while trying to find out how people do their dual pump setups with no luck, so I thought I'd post up... just so the search button would pop up something good.
Just to explain, this is so you can have two walbro GSS341 255 (high pressure) lph fuel pumps in-tank. One pump can handle 500-550 rwhp.
John
Old 03-21-05, 11:42 AM
got_trd
got_trd's Avatar
you have more than 550whp?
Old 03-21-05, 01:49 PM
SupraCoup3
SupraCoup3's Avatar
I've got a project going on right now... no details yet
Old 03-21-05, 02:18 PM
rscott
rscott's Avatar
you mean the $450 WOTM bracket?
Old 03-21-05, 05:48 PM
got_trd
got_trd's Avatar
Interesting.... Keep us updated..
Old 03-21-05, 06:41 PM
TurboB6
TurboB6's Avatar
I went about dual pumps a little different. My tank is sumped on the bottom feeding two external pumps
Old 03-21-05, 07:17 PM
rscott
rscott's Avatar
which setup are you using? Also, how noisy is that?
Old 03-21-05, 07:30 PM
TurboB6
TurboB6's Avatar
Its more of custom setup to say the least. Running two external bosch pumps. Compared to the Weldon or SX pumps its not excessively "noisey".
Old 03-21-05, 08:31 PM
rscott
rscott's Avatar
can the stock bracket be modified to hold two pumps via some sort of clamp?
Old 03-21-05, 08:43 PM
gowest
gowest's Avatar
this might help....
Old 03-21-05, 08:44 PM
gowest
gowest's Avatar
more pic
Old 03-21-05, 08:46 PM
gowest
gowest's Avatar
Note : do not place the pump too close the magnet will interface each other.
Old 03-21-05, 08:48 PM
gowest
gowest's Avatar
add relay so voltage stay at least 12V
Old 03-21-05, 10:13 PM
bambooluv
bambooluv's Avatar
I have yet to take apart my sc but I dont think the sc setup is like the ls400???any which way im gonna have some one weld something similar to what all the supra guys run to make my dual pump setup work...
GTE_SC3
24
06-30-08 03:13 PM
bugeyeGS
Performance
04-09-08 08:49 PM
blaznsc4
03-28-05 12:17 PM
braheem
03-05-04 09:01 PM
Quick Reply: Dual in-tank fuel pump brackets
