1JZ Clip Question
Originally Posted by nism0
I am getting a 1jz for my car. The car is currently a 5-speed. The shop that is doing the swap recommended that I buy an automatic soarer clip because it will be cheaper that a 5-speed and the motor will probably be in better condition because it would not have been beat on. They said that they just have to change the bell housing on my stock transmission to fit the 1jz.
I found an automatic clip that appears to be stock but it has 92,000 miles on it, should I buy this clip or look for another one?
I posted on supraforums, but didn’t get much of a response.
Any information will be greatly appreciated.
Thanks.
Thanks.
Originally Posted by gowest
Better go with 2JZ-GTE from aristo, it will mount to your 5speed with ease. About 1jz-gte with 92miles, that translate to about 150,000 km. That consider very high for Jap engine. Although 1JZ twin turbo is strong engine but people in Japan don't drive much and usually throw away car if it occure in accident. Low milege engine is plenty so better be patient and look else where.
there's no documentation out there that i can find on a JDM-model 2jz-gte... the wiring is different than the 1jz and different from the export 2jz-gte...
