1JZ-GTE swap almost done
#61
Originally Posted by bigdaddyrobb
Also will plug and play sc300 aem ems work if going to higher levels.
not to say it couldnt done, or that AEM could release a new module that supports the harness plug (it'd be the same for the 1jz supra and the soarer)... maybe someone should petition them it'd be nice to have everything already setup up almost (just plug in a GM map sensor instead, use existing IAT, etc)
their universal setup could do it most definitely... or you could use a haltech or something similar
#62
Just to clarify, you use the jdm ecu. What about boost cut/fuel cut. Also will plug and play sc300 aem ems work if going to higher levels. Is it really this easy and cheap? Could a novice do it? Does it retail curise and keyless entry? I work on my car but have never done a swap. Trying to decide between na-t or 1jz but like the 1jz because it looks cleaner than 2jzge.
Thanks
Thanks
Oh my friend buy 2JZ-GTE plastic engine cover and swap out 1JZ unit , it look better.
#63
Originally Posted by gowest
yes, 1JZ-GTE will look cleaner than 2JZ-GE, no intake pipe across the engine. SLD is also need if you want to go more than 180 KPH. For ECU upgrade look for Apexi Power FC or cheaper Greddy E-Manage if EMS has no application for 1JZ-GTE since it not US spec. Both units is plug-in and are affordable than HKS F-con V.
#65
Originally Posted by 2.5tsoarer
yes and valve covers, Ive seen it looks nice but still have dist. cap with wires doing into it
Wait, now I'm confused. Are you talking about swapping valve covers onto a 2JZGE or the 1JZGTE?? The last time I checked, my 1J doesn't have a distrib.
#66
Are you guys talking about plastic covers as in the spark plug wire cover that runs between the valve covers? I dont think it fits. Last time I checked the bolt holes on the 1jz arent wide enough
