2JZ-GE/1JZGTE Decision HELP NEEDED.
Old 04-17-05, 02:14 PM
huNGjaii
huNGjaii's Avatar
Default 2JZ-GE/1JZGTE Decision HELP NEEDED.
I currently drive a 96 5 SP Sc300. I am a fiend for boost, but very unsure on which route to go about. Im currently running on the stock Sc300 2jz-ge block with about 108,000 miles. Before reading a couple million threads I wanted to do the 2jz-gte swap . But I find out its way to expensive for me considering I'm a broke as a joke college student. So I was either planning to do a 1jz-gte swap or boost my existing 2jz-ge block. (make a custom 2jz-gte ). I was curious which would be more "economical". I figure that the 2jz-ge block is more capable of handling more boost. But I figure if I push high psi's I'd prbably have to rebuild my original motor. Comments/Suggestions/Opinions/Respones please ?
Old 04-17-05, 02:19 PM
got_trd
got_trd's Avatar
I suggest you read through the other threads about 1jz/2jz-gte conversations. Just scroll down in this FI section and every other one is about a 1jz swap
Old 04-17-05, 02:48 PM
huNGjaii
huNGjaii's Avatar
Sorry for the ****ty post. I found the thread I was looking for. Thanks TRD. So I'm going with the 1jz swap. I was wondering how difficult it would be to do? I was planning to have my brother help me with it because he is pretty knowlegedable, but he has not done a engine swap before. Is there a manual out there that I could purchase to assist me? Or something along the lines of that?
Old 04-17-05, 03:30 PM
got_trd
got_trd's Avatar
Quote from 2.5tsoarer- "Well, I must admit . This is the easiest swap I have ever done. In 1997 I was the first to do sr20det swap on the East coast and found out the hard way what to do and NOT to do. Well with this swap no body mods are required to install engine and stock intercooler piping. All the holes are there and bolt holes tapped. I started removing stocker at 5pm and finished completely installing 1jz 5 hrs later. I didnt even have to remove hood !!!"
Took him 5 hours to remove the 2jz-ge and drop in the 1jz... Wiring is simple. You'll need to extend the harness if you want it to rest in the intended ECU location of just let it sit a little higher
Old 04-17-05, 05:06 PM
Aristo300
Aristo300's Avatar
Chino did you have the same ease with your swap? What kind of power can you expect out of the 1jz with full exhaust/intake & increased boost?
Old 04-17-05, 05:44 PM
got_trd
got_trd's Avatar
I didnt do my swap. I was in between cars when I found mine so I just hopped on it. However, I do plan on doing the swap sooner or later with one of my friend on their car.
In my car, stock except for the 15psi i've stayed right next to a BPU Supra. We ran twice from about a 20mph roll and it was neck and neck up to about 100mph. Fun times I cant wait till this weekend when I move back home and get to drive my car again
Old 04-17-05, 06:49 PM
huNGjaii
huNGjaii's Avatar
Is there anyway to get the 1jz passed smog legally without knowing someone in the smog business? Loop holes or what not? Because the car would be useless if I can't drive it. Anyone in California with a swapped engine with some knowledge?
Old 04-17-05, 07:03 PM
got_trd
got_trd's Avatar
Sorry, cant help ya there... I live in FL and we dont have emissions so im not worried about it
Old 04-18-05, 07:06 AM
kaotiq
kaotiq's Avatar
Good luck passing smog with the 1JZ. I had to have "someone" smog my car.
Old 04-18-05, 10:20 AM
huNGjaii
huNGjaii's Avatar
Yah I'm planning on taking to one of those shady "You pas or we pay" places. Haha and I hope I pass.
esc300
SC- 1st Gen (1992-2000)
09-01-14 08:47 PM
socalturbo
02-12-11 11:37 AM
zludespide
IS - 1st Gen (2001-2005)
17
10-03-10 03:08 PM
Henessey
07-07-08 06:55 PM
Quick Reply: 2JZ-GE/1JZGTE Decision HELP NEEDED.
