1jz-gte SHES ALIVE!!!
Old 04-22-05, 06:54 PM
2.5tsoarer
2.5tsoarer's Avatar
Default 1jz-gte SHES ALIVE!!!
I must say the extending the wires took longer than the engine swap itself.. I will post details on this swap if anyone would like I will also include pictures and step by step instructions . I will post as soon as I write it up.
Old 04-22-05, 06:59 PM
reamemiya
reamemiya's Avatar
GOOD JOB!
told you the harness might take a while
Old 04-22-05, 07:02 PM
vredniykot
vredniykot's Avatar
way to go!
i would feel like a little kid with a new toy
Old 04-22-05, 07:03 PM
2.5tsoarer
2.5tsoarer's Avatar
Originally Posted by reamemiya
GOOD JOB!
Yes 200' of wire 15' of heat srink tubing, and a 1 1/5 spools of solder
Old 04-22-05, 11:16 PM
rscott
rscott's Avatar
what did you do about the knock sensor?
how much did each wire need to be extended?
Old 04-22-05, 11:28 PM
Mr. SC300
Mr. SC300's Avatar
Congrats man
-romeo
Old 04-23-05, 12:39 AM
mteele
mteele's Avatar
Harness needs to be extended 18"-21".
I went and bought some heat shrink today at Home Depot, but I guess I should go back and buy the rest of what thay had, hehe
What type of wire did you use? Can't wait to see it man!!!
Old 04-23-05, 04:53 AM
2.5tsoarer
2.5tsoarer's Avatar
I bought 16gauge but the OEM wires are 18 or 20 gauge with like 2 thicker ones.
When extending the wires 18" I desides to do it in 2 spots so I wouldnt have a big knot later. so I did half in the middle of tha harness behind the cam cover adn the other half by the plugs. I left the knock sensor extending by the plug . the original wire reaches into the cabin just not all the way to the ecu so I didnt use shielded wire. some people dont extend the harness, I cant see leaving the ecu dangling where its not supposed to be. I sold my cluster because I thought I was getting JDM .
BTW, I think the temp gauge is just a matter of finding the right resistor to install on that wire. b/c it goes up half way when you turn the key them goes to hot after car reaches normal temp. so finding a resistor to lower the needing about 60%. Tach I have no idea. on 89-90 240sx with srswap you can either get 91+ tach or install some msd tach thing.
Old 04-23-05, 09:26 AM
Khaos
Khaos's Avatar
Congratulations! I can't wait to see your write-up...
Old 04-23-05, 11:19 AM
blacksc400
Car Chat Moderator
blacksc400's Avatar
clean install, is it JDM soarer turbo????
Old 04-23-05, 02:16 PM
got_trd
got_trd's Avatar
Congrats man! Let the mods begin. How does it drive?
Old 04-23-05, 04:14 PM
ki_soarer
ki_soarer's Avatar
wanna come to gainsville next weekend, and help us with matts swap?? you know you wanna! hehe. we may be calling you for wiring help.... possibly... so you should pm your number to either myself, or matt (mteele), or chino(got_trd) . that is if you want to. thanks.
Old 04-23-05, 04:31 PM
2.5tsoarer
2.5tsoarer's Avatar
Im going to Miami next weekend sorry. From what I know got_trd didnt do his own swap
Old 04-23-05, 04:36 PM
Bean
Bean's Avatar
can you give me a more detailed description on the knock sensor wiring extension?
I'm understanding that you extended it? And you made the extending near the plug (on the engine side? not the ecu side?)
I would still use shielded wire since various RF waves might be able to interfere with the signal even when under the carpet/dash, etc
Old 04-23-05, 04:56 PM
2.5tsoarer
2.5tsoarer's Avatar
I extended the wire from the ecu side. the soldered end is about 4" in the cabin.
Quick Reply: 1jz-gte SHES ALIVE!!!
