Vid or Sound clip of 1JZGTE??
i think it was houston
oh well. i have 3 vids of clints old SC running on the highway. i thought the car was single then... or was that after? i dunno, i just wanted to post something.
does anyone know if that was his 92, or the 97 that he later sold to SW? i think it was the 92, cause that was the first one to get "the treatment"
Since the SC300 already has a 2JZGE in it, I can easily mate a 2JZGTE to the SC300 tranny. My question is, will a 2JZGTE from an auto supra work with a 5spd SC300 tranny if I get the supra 6spd Manual ECU? And what are my options after surpasing the limit of the SC300 stock 5spd tranny?
R154 and V160 are your manual tranny options after surpassing the W58
R154 would need a 1jz flywheel, slave cylinder, 7m clutch setup and custom driveshaft
V160 would need 2jz-gte flywheel, slave cylinder, and 2jz-gte clutch setup and custom driveshaft
Originally Posted by Bean
yes! you might have to do a little wiring trick to make the ecu think its in park so the motor cranks...
and with the V160, will the shifter come up through the normal spot on the console or will I have to modify it? and the V160 is the 6spd so I should get the 6spd ECU?? Im kind of confused, but what I do know is I want a 2JZGTE in a SC300 nnnnnnnnNNNNNOOWWWW.
Thanks for posting vids everyone you are helping me justify spending ridiculous amounts of money.
So I can use a 2JZGTE auto ECU?
depends on what year car you have to how much banging you need to do to make it fit
95+ cars will allow it to bolt right in
