A Few Questions for the 1JZ-GTE Owners
make sure you also measure the diameter of the pipe itself. The flange may be shaped the same to easily make it assumable that its interchangable but the sizing may be different. I know for a fact that the jdm and usdm downpipes do NOT match. I found this out when an mkiv friend of mine picked up a greddy turbo back 4" system from japan that was supposed to bolt right on. For whatever reason we decided to work from the back to the front. After fighting with the v-bands for quite some time it was finally time to bolt it up to the collector only to find the jdm exhaust flange was too small for the usdm TT output flange. Solution: Reflange the DP to mate up to the stock manifold.
Point of the story is you can use a mkiv DP with the worst case and probably scenario being that you have to reflange the turbo side of the pipe.
Can someone measure the distance between studs on the 1jz downpipe (or the turbo y-pipe outlet)? I have a standard 3" 3-bolt flange that the MKIV uses and I can take other measurements on it here...
I took a picture of my 2JZ MK4 downpipe and measured it. also got a pic of the 7m flange but dont have measurements. and here is a link on supra forums on this subject
http://www.supraforums.com/forum/sho...d.php?t=277696
If anyone needs measurments of a Soarer's 1JZ downpipe, I can get them off mine tomorrow. Let's get this **** figured out, I want to get rid of my cats
Originally Posted by mteele
I dont see why I cant just cut off my stock flange and weld it onto the MKIV downpipe off eBay.....
-Does the supra TT downpipe bolt up to the 1JZ exhuast manifold? No, not without modification (if at all)
suprandsc
Performance & Maintenance
07-17-13 01:38 PM
