mteele's 1JZ swap pics (56K take a nap)
#35
Originally Posted by jedc
Hey mteele, very nice swap and car. What are you gonna do about the ecu? Is it gonna be a problem running it since it's from an auto car?
#37
Originally Posted by SCandilous
i couldnt figure out how to get mine to start so i just wired that relay switch to a secret switch inside the car. it works as a theft prevention too i guess.
#39
#41
Originally Posted by DETUNED
do you have the wiring digram for your turbo timer? I'm sure I can figure it out, but if you already have it, why waste my time
#42
car: 12v ( white) - turbo timer (red)
car: Accessory (pink/blue) - turbo timer (blue)
car: Ignition2 (blk/orange) - turbo timer (green)
car: chassis (ground) - turbo timer (black)
#44
Originally Posted by 2.5tsoarer
Gosh you seem to be a genious at everything else, running a simple wire from ignition switch to started that mind blowing
automatics and 5 speed use totally different way to engage the starter after the ignition switch has been turned. you cannot just run a wire from the ignition to the starter because the starter draws way too much current and would burnout the ignition. thats way a relay is involved. in order for that relay to be switched on it has to get the signal from that clutch pedal switch on 5 speeds, or park nuetral switch on automatics. i could run the signal from the clutch switch to the p/n switch but i dont feel like doing it when wiring it to a switch inside the car was easier. my car just simple starts like a s2000 now or the new lexus gs's.
im not a genious at everything but i do understand electrical systems pretty well. from now on dont make stupid post.
mteele, i can show you sometime what switch you can use to start the car if you want to do it this way or what you probably need to wire to get it to start the normal way.
#45
you think thats all that is involved in starting a car?
