Post your 1jz swap issues
Old 05-04-05, 06:14 AM
2.5tsoarer
2.5tsoarer's Avatar
Originally Posted by Bean
hope it works too i still would rather just rewire stuff than spend more money... would be nice to have the info out there for people on a budget
think you can tell me the tach wire color Ill try jumping it
Old 05-04-05, 10:37 AM
SCandilous
SCandilous's Avatar
tach out is a blk/white wire
i have my msd tach adapter on order as well.
wonder if summit is wondering how come all these people are odering this part all the sudden
Old 05-04-05, 11:37 AM
mteele
mteele's Avatar
LOL, yeah
Where in Florida are you?
Old 05-04-05, 11:49 AM
gttosc
gttosc's Avatar
can a 1jz-gte swap easily be done with a stock 5 speed sc300 transmission?
Old 05-04-05, 11:50 AM
DETUNED
DETUNED's Avatar
research...
Matt, SCandalous is the guy who called scott to tell you guys how to get the car started.
Old 05-04-05, 12:22 PM
DETUNED
DETUNED's Avatar
Also, your airbag light is on because you disconnected the battery. MOST of the time it comes on whenever you mess with the battery.
Old 05-04-05, 12:24 PM
Bean
Bean's Avatar
that is specific for 1jz ecu right? because my airbag light doesnt come on cept at startup like its supposed to and i've reset the ecu plenty of times... (on my 2jz-ge of course)
Did trying the tach wire give a good tach signal?
Old 05-04-05, 12:53 PM
2.5tsoarer
2.5tsoarer's Avatar
Well the 330ohm resistor works !! wired it behind cluster on yellow w/ green striped wire(on the middle plug)
seems the cluster I borrowed to test was off or broken. the middle is just under half now
Old 05-04-05, 01:16 PM
rscott
rscott's Avatar
have you guys tried fixing this with the diagnostics tc/ab to the negative post of the battery trick? Or does the 1jz not have the diagnostics port?
Old 05-04-05, 01:57 PM
ki_soarer
ki_soarer's Avatar
research...
yea, rich has my old SC!!! im so glad its got the GTE now... it needed it.
as for the airbag light, i dont think it has to do with the battery... i think thats if you turn on the car with the cluster out. i know there is a way to read the codes, but i dont know if that would work with the 1J or not. its more than likely an ECU problem. thats my thoughts.
so we will know if the tack addapter works soon, and the 330ohm resistor does work for the temp, now we need to figure out the oil and airbag lights, and the ignition problem... (withought a ghetto jump) lol.
Old 05-04-05, 02:00 PM
Bean
Bean's Avatar
so thats 330 ohms? not kohms? and this is for the water-temp sensor right?
we need a sticky!
Old 05-04-05, 02:13 PM
ki_soarer
ki_soarer's Avatar
i dunno, i was going off of what he said.... we do need a sticky though.
Old 05-04-05, 02:31 PM
2.5tsoarer
2.5tsoarer's Avatar
we need a sticky!
DUDE I wrote 330ohm !! these post to write will start to confuse people.. Yes For The Water Temp Gauge.
Old 05-04-05, 04:07 PM
2.5tsoarer
2.5tsoarer's Avatar
Default 1jz upgrades
has anyone done upgrades to their 1jz and noticed difference a bit later. seems the ecu takes a couple of "on and offs" to learn new mods. I upgraded to a front mount intercooler and at first it felt slower and throttle response sluggish. but after 2-3 times driving the car everything seemed to adjust and I cant tell the hp gain. car breaks the tires loose (automatic)
Old 05-04-05, 05:56 PM
kaotiq
kaotiq's Avatar
Not really, my car felt just perfect righ from the bat. You might want to check for some loose connections that might have occured during test runs.
Quick Reply: Post your 1jz swap issues
