Post your 1jz swap issues
#91
Originally Posted by Bean
Bump on this post; please all 1jzers report in for fixes ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Anyone fixed the tach problem? what about the water temp problem? other dash issues?
let's hear it!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
let's hear it!
#92
Mteele, werew you running an 1jz auto or manual ECU. I have a 5spd car with an auto ecu. How do u bypass the check engine light(if u got one) from the ecu trying to find the absent A/T trans.
Also did you guys solve the tach issue?
#94
Originally Posted by blksc300mt
i was wondering the same thing about the auto ecu in a manual car...an has anybody actually used the msd-8920 to make the tach work yet?
btw: where in FL are you?
#95
yea..it really sucks what happened to his car. im in miami. i talked someone at jhot and they told me they should have some 1jz's in at the end of the month..i have the cash in hand so as soon as i get one of em ill be doing this swap too...keeping it all stock for now...so im just gonna order the 8920 and try hooking it up since its only like 50 bucks....dosent look too complicated...just not sure if the tachs in our cars are voltage triggered or current triggered cuz you have to wire it differently...
#96
So sputter right before the tranny shifts when on fulll throttle people thought was boost cut and/or fuel cut. since my swap did it even stock I'm thinking its the US auto transmission ecu that is causing it. So I asked my friends in Japan to ship me a soarer transmission ecu. I will keep you posted on this issue.
#97
there are a bunch of people selling soarer auto trans in the states if that will help with shipping considering its pretty big and heavy. is the auto trans ecu separate from the main ecu? i thought it was the same ecu that controls everything else that controls the tranny.
#98
#99
#101
of course not the tranny ecu uses this signal. what wire you disconnected ?
are you comnig to look at my stock twins ?
I think I figured out why my car was smoking and its not doing it anymore. I pulled all the pipes off yesterday and checked the play and it was little to none. But as of right now, they're working fine. Ill pm you if that changes. I might want them in a month or so just to have..
#102
i have a few questions for u guys. I drive an sc 300 automatic. Im in the process of swapin that **** out w/ the 1jzgtte. I need to by a u sed turbo bak exhaust for the 1jz motor that will fit w/ the exhaust manifold egress, on the 1jz. Because the motor in my sc has 2 ports for the exhaust to exit. My 2nd question is: how do i tell the difference between the w58 and the r154 tramsmitions. Does anyone here know. Please write me back
