1jz gte timing belt and cams
#31
Originally Posted by Gamer
The FCON S would be the best bet for your goals. It controls the fuel/air and the ign control.
I should add that I use the AEM C2DI to enhance the spark.
Atleast with emanage I can tune it all I want
#32
#33
Originally Posted by kaotiq
I was researching this yesterday actually. Piggy backs like the PFC, SAFC, AVCR can only push the stock limits so far. Here is our problem. Our stock injectors run at 340cc and it will be extremely difficult and/or impossible to get the piggy backs to double the injector pulse....say to 650cc. The piggy back systems might be able to push our injectors about 75% more than they should, but that is about it.
Now, 650's are EASILY tunable on a PFC. As a matter of fact, one of my good friends just tuned 1400cc injectors on his 600whp 240 using a PFC. I think you are confused about how piggy backs work. You can't make the stock injectors bigger with a piggy back. you can only replace the stock injectors with bigger ones then tune using a piggyback or some other Engine Management system.
Full Standalone's such as Haltech, Tec2,3, etc are a pain in the *** on daily driven cars. And imo are not worth the trouble, when you can get very similar results from a PFC or FCON.
#34
One of the UK guys running his stock turbos at 18psi (fmic/440's/e-manage) had some slight det problems but I think they tuned it out.
#35
Originally Posted by JZZ30TT
I disagree. A PowerFC can be had for about the same price as a FconS and is much more tunable than the S.
Also the power FC will NOT work with the auto box.
BTW I ran my stock turbo's for 1 year at 1.2bar (17.5psi) with no problems. Mind you I had an FMIC/440's/custom dumps/large bore single/fcon/evc keeping it all nice.
#36
Ok, PFC is not a piggy back. AVCR is a boost controller. The only piggy back you listed was the AFC.
EDIT: this is assuming that you have aftermarket injectors on already. The piggy backs have their limits. Hence, why everyone decides to spend the money on the standalones.
#37
That would be because the Power FC is a "Full" stand alone ECU, the FCON S is a Piggy back !
#38
*sigh* No I'm not confused on how a piggyback works. I am quite aware since I had the VAFC and AVCR combo on my turbo honda years back. Yes you are right, the PFC is NOT a piggy back, my mistake. If you read my EDIT, I said
#39
Well, if you can have a PFC for the same price.. why wouldn't you want that? Easy to tune and you are able to tune it with out an authorized dealer now that the FC logic is out.
If however I was trying to save a few bucks I would have no problem selecting the PFC as a solution.
#40
I agree with you on that. The only reason why not is because of the Auto box. If I had a manual I would have gone for the AEM or FCON V Pro anyway and passed the PFC by.
But, after messing with a couple PFC's w/ FC logic.. I am really impressed with it.
#41
That's all fine but I was just saying you can run decent size injectors on a AFC. 550's are small injectors, and would easily be able to be tuned on a AFC, as well as 650's.
#42
and its very easy to get certain piggybacks to double the injector pulse...
you either need a wider range map sensor with appropriate injectors to match and a fuel controller to tune
or you can use a greddy emanage and it will do it just fine...
SupraTT 550s, JDM Supra MAP sensor and a S-AFC goes a LONG ways... 500whp actually with appropriate fuelpump
