1jz gte timing belt and cams
Old 05-07-05, 09:47 AM
  #46
Gamer
Gamer's Avatar
Default E-manage/650cc/1JZ-GTE
Found a really informative thread about setting up the e-manage with larger injectors on the Australian Soarer forums.
It is in two parts, but well worth a read if you plan on going that route.
Part 1
Part 2
Old 05-08-05, 07:31 PM
  #47
GRIFFIN TT
GRIFFIN TT's Avatar
Originally Posted by Bean
SupraTT 550s, JDM Supra MAP sensor and a S-AFC goes a LONG ways... 500whp actually with appropriate fuelpump
So your saying that this is the recipe for 500whp single turbo afc setups.
1JZ map sensor is not sufficient??
  #48
GRIFFIN TT
GRIFFIN TT's Avatar
Part 1
Part 2
good find gamer
Old 05-08-05, 07:44 PM
  #49
Bean
Bean's Avatar
not unless you plan on running less than 15psi of boost, and you'll still need injectors and a way of controlling them to get to that point... using the 2jz map sensor makes it hella easier by allowing for more boost and for having a easier time of tuning large injectors since its made to work with 440s, not like the 1jz map which is setup for 380s
Old 05-09-05, 07:24 AM
  #50
GRIFFIN TT
GRIFFIN TT's Avatar
do you know a good source for a jdm 2j sensor
Old 05-09-05, 07:36 AM
  #51
kaotiq
kaotiq's Avatar
ebay.... supra forums?
Old 05-09-05, 11:40 AM
  #52
JZZ30TT
JZZ30TT's Avatar
Terry, look in the drivers side door pocket. I had one on the car for several weeks, to test it out. I took it off and put it in the door pocket. There should be one still in the car somewhere... if not let me know and I'll look through the **** I took outta it when I sold the car.
Old 05-09-05, 12:22 PM
  #53
GRIFFIN TT
GRIFFIN TT's Avatar
I will check it out tonite...actually there is nothing in the drivers side door pocket. I probably gave it back to you when we cleaned out the car
Old 05-10-05, 08:36 PM
  #54
ravaz
ravaz's Avatar
Where do you guys see a Power FC for sale for the 1JZ? I can't find anything, but then again I'm probably looking in the wrong places.
Thanks.
Bill
Old 05-10-05, 08:38 PM
  #55
got_trd
got_trd's Avatar
Thanks.
Bill
There is one every now and then on ebay. Most of the time I go on ebay and search under 1jz or soarer ill find it.
Old 05-10-05, 10:19 PM
  #56
JZZ30TT
JZZ30TT's Avatar
Thanks.
Bill
Yahoo Japan Auctions has a doo doo load of em usually, generally pretty cheap too.
Old 05-10-05, 11:44 PM
  #57
Gamer
Gamer's Avatar
Scroll 1/4 down the page....
Power FC
You prob don't have the VVTi but this seller might be able to source a non VVTi version....
E Bay Power FC for 1jz-gte VVTi
This place also sells the Power FC
Oo Parts Japan
Old 05-11-05, 06:27 AM
  #58
ravaz
ravaz's Avatar
Awesome, thanks guys.
Marckussb
03-16-14 09:19 PM
Tinkler
09-29-09 07:07 PM
aswang
08-02-05 02:56 PM
Kaiser
05-20-05 08:10 PM
Quick Reply: 1jz gte timing belt and cams
