View Poll Results: Is this post helpful?
Yawn garbage
7.32%
Meh...
21.95%
Some one needs to stick this or i'll.................
31
75.61%
Multiple Choice Poll. Voters: 41. You may not vote on this poll
1jzgte Wiring Info!!!!!!!!
Old 03-12-06, 11:50 AM
JJG2005
JJG2005's Avatar
Sent a PM about the wiring diagrams, hopefully you're still around this site.... if not, anyone know anywhere else to find the soarer wiring diagrams in English?
Old 03-12-06, 06:15 PM
philauldridge
philauldridge's Avatar
Default Soarer diagrams
HI,
Please send me a direct email: phil @ auldridge.org
I should be able to help you
Phil
Old 03-14-06, 12:01 PM
VJ RC51
VJ RC51's Avatar
Easiest swap is a GenII 1JZGTE. No modifications to the car what so ever. Only have to extend 40ish wires. Plug/play, and go.
Old 06-13-06, 01:26 PM
jdmjeremy
jdmjeremy's Avatar
can anyone verify that the gen II version is that direct of a swap? does everything work after?
Old 06-14-06, 10:08 AM
LocknRoll
LocknRoll's Avatar
genll is vvti...or not?
Old 06-14-06, 01:19 PM
5spdSC300
5spdSC300's Avatar
genII doesn not have vvti
Old 06-14-06, 10:31 PM
lsflame
lsflame's Avatar
Go with Gen 1 swap and its easy as pie just extend the Body plugs and you are done.
Old 07-11-06, 12:32 PM
RS3
RS3's Avatar
Can you elaborate?
Old 07-12-06, 01:28 PM
BigWaveSC
BigWaveSC's Avatar
I am ready to start this swap and trying to plan ahead.
Gen 1 and Gen 2, what years are these.?
and all I have to do is extend wires ,
if true that will be awsome.
Dave
Old 11-22-06, 03:30 PM
sc250tt
sc250tt's Avatar
i think mines is a gen 2 thats all i did but then again my car is a 92 i did not have to wire up my alternator like others here or neither did i have to wire anything to the fuse panel under the hood .all i can say is try to get a engine the same year of your car and it will make things much easier and for the wiring do not cut the computer side of the harness, jus cut the body plugs. the less wires you cut the easier it is to troubleshoot .
Old 12-05-06, 12:52 PM
96gti2.0t
96gti2.0t's Avatar
do u guys know if th a/t ecu will work or will the stock 5spd ecu work with the 1jz swap?
Old 12-05-06, 02:27 PM
philauldridge
You will need the AT ECU if you are using an A/T. Otherwise, if it is a manual tranny, it really won't make too much difference
Old 12-05-06, 06:32 PM
drnkcarlos
drnkcarlos's Avatar
AT ECU will work fine aside from the annoying errors messages for gear and ets (or etc??) the digital display would pickup... not sure if you'll get those same errors on US display. but if you can't live with the errors messages might want to swap it to a manual ecu asap.
Old 12-05-06, 07:32 PM
96gti2.0t
96gti2.0t's Avatar
ok thanks for teh help thats what i tought but wasnt sure
Old 12-11-06, 09:23 AM
96gti2.0t
96gti2.0t's Avatar
what are you guys using as far as intercooling goes?
Quick Reply: 1jzgte Wiring Info!!!!!!!!
