SC300 Automatic Transmission Shifting Hard
Originally Posted by OakTwnPnoy
I don't think it's the fluid. I think your shift actuator is bad.
"Commonly used accumulators rely on the action of a piston or a valve to delay the delivery of high pressure of a clutch or band. An accumulator works like a shock absorber and cushions the application of servos and disc packs. An accumulator cushions sudden increases in hydraulic pressure by temporarily diverting some of the apply fluid into a prallel circuit or chamber. This allows the pressure to gradually increase and provides for smooth engagement of a brake or clutch."
That was from my classroom manual.
If you've exhausted everything you can on the gearbox (without having it rebuilt), you might be better off getting a secondhand auto and whacking on a shift kit (which I will most likely do), even as a temporary fitment.
abounly
Performance & Maintenance
06-02-10 01:41 AM
scsrock
11-25-03 06:31 AM
