Tranny Options
Originally Posted by PM Supra
stock sc300 auto rear end. If you use the 6 speed diff for cruising, it is cool. However it won't get out of the hole.
Chris
Strange I don't consider the th400 option "pure drag". I've driven mine many times on the street w/ the auto rearend (3.76) and love it.
And I don't believe topping out at 120mph is entirely accurate. It depends on several varibles.
Originally Posted by soarer479
th400s are great if u wanna be pure drag and top out at 120 mph ... they will take as much abuse as u can give them and are decently daily driveable (it will drive like an old cadillac) but this swap is costly and i want some top speed. i have the same problem as you. i have opted to buy a supra tt auto and have it built by boost logic then all you will need is a custom drive shaft a small amount of wiring and your done. in my mind much easier and cheaper as for reliability i trust kean. obviously it wont be as reliable as a th400 or a turbo 350 but im sure will get the job done and besides i could afford to do the tt auto swap twice for the price of just the th400 conversion kit
This should provide details:
https://www.clublexus.com/forums/sho...rear+end+ratio
TT transmissions can get expansive too after you brake three of them. Not to mention to built it up you will have to pay around 3200 dollars.
Chris
Is the GTO turbo, because most 400's required vacuum to assist with the shifting.
Our supra drag car will go 159 @ 9K with 28" tall tires. It has the supra auto diff (3.73). SW's old 95 supra would go 154@ 8500 with a 6 spd diff (3.27) on 26" tires. I have also installed a Gear Vendors unit behind a BL400 strictly for cruising. It kicked the rpm back by about 600 rpms.
All race transmissions are manually shifted.
Also had a question on the GV setup. Have you done any WOT testing with it? Or just cruising tests?
Originally Posted by TurboB6
Maybe I misread this but by this statement your implying the th400 is a race tranny? I consider a Lenco or Jerico more-so of race tranny then the th400. The th400 is on the extreme side of a reliable streetable tranny for the sc/supra imo.
Originally Posted by 313sc3
I know what the gear vendors unit is but what is a BL400?
Originally Posted by sc300tt
Hey Jeff. They haven't tested it at WOT to my knowledge, but it's rated to like 1200hp. It's a tough unit.
BoostLogic TH400 for the 2jz
i am not worthy!
