Idling very high on SC300
i just cleaned the throttle body on my 95SC300, with the spray cleaner and right after i put the stock intake tubing on, started the car, first it was idling at around 2200, well it came down alot but it stilll idles between 1200 - 1500, any help would be appreciated
thanks
thanks
Did you take off the TB and clean it with a rag and TB cleaner, if so you might have plugged one of the holes that the vacuum lines run into. Some of the holes are very small.
I cleaned the my TB and plugged up the holes and the my car ran like cr**.
Try spraying the TB cleaner into the hard lines the vacuum lines that run into the TB and make sure they are clear.
I hope this helps
I hope this helps
thanks for your reply bro, but i didnt take the TB off, i left it on there , i just took the intake tubing off the throttle body and sprayed throttle body with the sprayer, it was real dirty, i hope i didnt mess up anything up, but i will check the vaccum hoses up see what's going on
yea the air flow sensor wire is plugged in proper, i never had to take the wiring out , but anyways i'll see for couple more days if it adjusts by itself, if not i am going to take the whole throttle body out and clean it out real good and see where it goes from there, but the car feels alot more responsive now
i was in the same situation as you when i cleaned my TB. when i was done cleaning it i started it up and the idle was high so i let it warm up and the idle was still high, i tried resetting the ecu, that didnt help me, so since i didnt know what to do i just left it like that and now my idle went back to normal.
-romeo
-romeo
DarwinX
RX - 1st Gen (1999-2003)
26
05-05-10 09:34 AM
