2uz-fe
Old 06-08-05, 05:05 AM
MyScRuNmIa
MyScRuNmIa's Avatar
Default 2uz-fe
guys last night i was out at the hang outs, an i was talking **** with sum of the guy's when some one said hey, i have a TOYOTA TUNDRA in my back yard that got hit from the side an bent in half but the motor trany an ecu are fine..he was like, if any one has 1500 lieing around ill sell it to them...i was like hmmm.....i looked up the specs on it 245 HP 315 TQ , compare to my 250 260, an TRD makes a supercharger for it. how hard would it be to drop that motor into my 92 sc400?
Old 06-08-05, 05:12 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,294 Likes on 1,399 Posts
I'm not sure about the year of your buddy's truck, but new Tundras come with a VVT-I motor, which would involve not only the motor but some significant ECU transplants from truck to SC which would make it difficult IMO.
Old 06-08-05, 05:17 AM
MyScRuNmIa
MyScRuNmIa's Avatar
yea it is the vvt-i model but he said for 1500 i get everything ecu trany ...basically what ever i want from the truck..how hard exact do u think it wud be..? just a wireing isue or more than that...
Old 06-08-05, 04:40 PM
Vegassc400
Vegassc400's Avatar
There is a member that used the interals from a 2uz to stroke his 1uz from 4.0 to 4.7 liters. I'm not sure on the details but do a search.
Old 06-09-05, 11:53 AM
Lextreme
Lextreme's Avatar
I just picked up a 2UZFE shortblock yesterday and doing a stroker for it and trying to get it up to 5.5 liter. I am also putting in some boost into it. I would like to put this in a SC400. Here are some pictures.
Left is Tundra and Right GS430 (2 bolt main vs. 6 bolt main)
1, 2 and 3uzfe Rod: (from left to right)
Old 06-09-05, 11:56 AM
Vegassc400
Vegassc400's Avatar
Oh boy. Looks like you have some work cut out for yourself David. What's the eventual goal?
Old 06-09-05, 01:28 PM
Bean
Bean's Avatar
hey, all those rods look about the same length!
is it the crank that gives the 2uz the extra stroke? (just like the 1jz vs 2jz)
Old 06-09-05, 01:43 PM
Lextreme
Lextreme's Avatar
I have done lots of research on the 1uz, 2uz and 3uz.... Here is an article about 1 and 3 uz rods
http://www.lextreme.com/rods.html Yes all uzfe rods are the same specs.... except 1uzfe is the strongest of all.
I am working very close with an engine builder using some other aftermarket off the shelve performance parts to stroke it. I am also trying to convert the 2 bolt main into 6 bolt main on the Tundra block......
My Goal: Stroke the 4.7 with boost and using 1uz heads... with 6 stud main
Read links below for details on block and pistons...
Old 06-09-05, 03:44 PM
sc300tt
sc300tt's Avatar
..I am working very close with an engine builder using some other aftermarket off the shelve performance parts to stroke it. I am also trying to convert the 2 bolt main into 6 bolt main on the Tundra block......
My Goal: Stroke the 4.7 with boost and using 1uz heads... with 6 stud main.
David, no offense, but why are you worried about converting the iron block to 6 bolt mains? I truely doubt that is one of the weak points, not to mention you may be opening up a can of worms and actually weakening the block. If you do anything, you might consider a girdle, but I really doubt even that is needed.
Old 06-09-05, 03:51 PM
Lextreme
Lextreme's Avatar
I am making a engine girdle right now for the 1uz and 3uz, but it would not work on the 2uz. Coverting the bolt is a lot of work. The goal is to get more cubic into the 4.7.
Old 06-09-05, 05:28 PM
MyScRuNmIa
MyScRuNmIa's Avatar
ok going back on topic, droping in a stock 2uzfe, or 3uzfe how much work am i looking at..would i use the same motor moutns or na?
Old 06-10-05, 04:21 PM
Lextreme
Lextreme's Avatar
You might want to read other site specialized in Lexus V8 Swap. There are lots of info on the net about 2uzfe swap into sc400. Here is a picture of 2uzfe into Supra MKIV engine bay. Its too tall and the hood would not close.
Old 06-10-05, 06:43 PM
sc300tt
sc300tt's Avatar
I bet that engine would fit fine without such a tall intake manifold.
And back to your 6bolt conversion, I really have no idea why you would want to even venture down that road. I can obviously understand stroking to over 5 liters, but the two-bolt iron block is fine for that, and drilling 4 more holes around every cap, into a block that was NOT cast to accept them is probably just going to make the block weaker.
Old 06-12-05, 06:29 AM
Lextreme
Lextreme's Avatar
Yeah... after i fully study the main caps.... its too much work and not really need. I will try making it 4 studs main. About the swap.... I am planing to use 1uz heads and intakes. That will clear the hood. 2uz intake is too tall and would not fit under the hood.
arpphoto
02-20-19 09:52 AM
arpphoto
02-20-19 09:50 AM
LocknRoll
04-09-06 09:07 AM
Quick Reply: 2uz-fe
