what is this
Old 06-08-05, 08:22 PM
mikevogel
mikevogel's Avatar
Default what is this
this piece is broke on my sc300 what does it do and how much would a new one be
File Type: bmp
Old 06-09-05, 07:16 AM
KidPandJ
KidPandJ's Avatar
bigger picture would probably help?
Old 06-09-05, 09:15 AM
mikevogel
mikevogel's Avatar
i tried to make it bigger but it keeps saying file to big over 100 kb or somthing that piece is right next to the intake manifold right over the fuel rail
Old 06-09-05, 11:41 AM
CleanSC
CleanSC's Avatar
Seems to be pointing at the Cyl #1 fuel injector. Exactly what part is broken?
EDIT: Looking closer that's a vacuum switching valve if you are pointing at the upper plug in the pic.
Old 06-09-05, 02:35 PM
mikevogel
mikevogel's Avatar
yeah not the fuel injecter it has two vacuum lines runing into it and a conecter. im wondering how much one would be or even what its called
Old 06-09-05, 02:50 PM
CleanSC
CleanSC's Avatar
Then that's the VSV for the EGR.
Old 06-09-05, 02:58 PM
mikevogel
mikevogel's Avatar
do you have any idea how much it would be what exactly does it do thanks for you help
Old 06-09-05, 03:00 PM
/Aerostar\
/Aerostar\'s Avatar
Yea its a VSV. My VSV for the heater broke (or was broken when I bought it), so my heater core wouldnt open up when I turned the heat on. After some research on Supra-forums I found that a VSV out of a late 80's to early 90's Toyota will work (more specifically, Camrys, Cressidas, and Supras I believe...). Go to a junkyard and salvage 1 or 2 "new" VSVs and test em out.
PS. Dont expect them to be a direct hookup, you may or may not have to splice the connectors (1 or 2 wires, no big deal)
Old 06-09-05, 03:05 PM
mikevogel
mikevogel's Avatar
thanks guys anyone from flordia know any good junkyards i just moved here i live in merritt island??
Old 06-09-05, 03:27 PM
CleanSC
CleanSC's Avatar
What exactly is broken on it? It controls the EGR valve so it's nothing catastrophic if it doesn't work. Most modded engines have this removed anyway.
Old 06-09-05, 03:47 PM
/Aerostar\
/Aerostar\'s Avatar
Yea like Clean said, that VSV isnt a big deal. Alot of people actually remove the whole EGR system (or remove parts of it and block it off). The EGR system recirculates exhaust gases back into the intake. its supposed to increase efficiency but alot of people remove it to reduce intake temperature, thus increasing HP. So you could either salvage a VSV from a yard (look up 'Salvage Yards' up in your local yellow pages, or online, whatever) or you could buy some EGR block off plates and remove the EGR system
Old 06-09-05, 04:36 PM
mikevogel
mikevogel's Avatar
it wont idle without that i tried to fix it but it didnt work i will probly check the junkyards how much is the block off plate i dont want to spend too much this motor has 180000 miles on it
Parson
11-15-18 03:32 AM
Superfast1
12-16-17 07:11 AM
coug66
11-10-17 09:28 AM
2jznosht
08-09-12 09:52 PM
INTIMAZY
09-01-11 10:14 PM
Quick Reply: what is this
