Yellowtop Fitment
Yellowtop Fitment
I got a Optima Yellowtop from my old car waiting to be installed in my SC300. The battery model # is SC34DU. The measurements are almost the same as my old battery with the exception of height; it is 1" in lower than the stock. So before I try to drag this heavy battery down to the parking lot n try to install it, what do u guys use to hold it in place?
put some rubber hockey pucks on the tray and youll be able to use your stock tie down. In the past i put one under each corner of the battery and then used the tie down. it never moved a bit.
jdanielca
09-12-18 03:39 PM
