which auto tranny?
Originally Posted by soarer479
thats why im running aem ems i spoke with an aem tech and he told me that the ems for my car would controll this tranny but they are four wire from the tranny that must be tapped into the ecu i also spoke with kean who just did this same set up with a customers sc300 so the ecu/ tranny mixture isnt a problem im simply trying to find the cheapest way to do a drive shaft
original tranny wont hold much more than 500 whp even when built before it goes thats why im swapping to the tt
Originally Posted by BrownDuckz
Boost Logic has made a few dozen 9 second second passes on there GE tranny that has been built, I can guarantee you that the car is making over 500rwhp - and it's being abused & won't break. The SAME hardparts go into the two different trannies - one isn't stronger than the other. I'm quoting this info on a talk I had with Kean @ Boost Logic...
Your memory is good. My BL built NA tranny failed in short order with just over 400whp. And there was no abuse.
Kean or Zohair posted awhile back on SF that the 9 sec pass tranny figures were for their TT built tranny not the NA built tranny. You think they bolted ta NA tranny to there 9sec TT motor using a cable to control line pressure? And the 2 trannies are not the same. The TT tranny uses more clutch plates which is why it is stronger.
Be careful of what you guarantee.
gadgetSC-t
gadgetSC-t
Even their built autos aren't standing up to many passes from what I hear. But then again, what do I know.
If you want to run serious power, step up to a 3spd and drop a 6spd rear in there.
James
James
gadgetSC-t
gadgetSC-t
James
James
Originally Posted by FortuneSC
from what i read on their site their built auto tt trannys are very good, they have one in a 900hp supra that has made over 40 low 10 sec passes and has registered over 25000 miles with no problems thus far
Boost Logic MKIV TT Auto Upgraded Transmission
This transmission was tested and developed on BoostLogic’s 9 sec@142mph daily driven street Supra. This transmission has been tested for over 25,000 miles and counting, as the Supra it was tested on is a daily driver. More than 40 low 10 second passes have been made on this transmission and it still drives like the day it was put in. It shifts FIRMLY and INSTANTLY. It doesn’t shift too hard to daily drive but will HOLD the power at the track. Many cars have been using this transmission and are loving it. The price of this transmission does not do justice to the level of performance this transmission puts out. The transmission is half the price compared to other competitors and is PROVEN to run 9's in the 1/4 mile. A working core exchange is required. Call for more details.
see, its a tt tranny
i was looking into the sound performance built tranny it seems to me that they build them much stronger and do alot more to help the tranny ... just sucks its so expensive and i dont have the money
Banned - could not follow forum rules
Can you guys give me any helpful info on the 93-98 Supra TT auto tranny that I plan to dump into my 1992 SC400? Any suprises that I may find when doint this swap? Any info would be most appreciated......
soarer NAT
Performance & Maintenance
11-19-03 10:43 AM
