Ran a Bit Better at the Track Last Night
Old 06-18-05, 08:40 AM
Easy2speed
Easy2speed's Avatar
Default Ran a Bit Better at the Track Last Night
It was about 80 degrees here in Montgomery last night. The track was about average for MMP - not too good, but not too bad. All 3 runs were with 93 octane on 16psi which I run on the street and the crappy 245 All-Season's. The first run I pulled in the staging lanes immediately after arriving because there was no wait. I bogged the first pass; then I finally got it going and hit second with only minor wheelspin. Third and fourth went by quick. I tried to avoid going into fifth and ended up bouncing off the rev limiter in fourth. I knew it was going to be a good trap because it will do 127mph in fourth!
Here's how it went:
60'----2.421
330---6.181
1/8---8.921
MPH--91.13
1000-11.219
1/4---13.122
MPH--118.87
With how many things went wrong on that run, I figured I could have pulled at least a 12.XX and something over 120mph by going into fifth a little early. That wasn't the case. I ran two more times with massive wheelspin in second. The second run had me looking at the wall on the left for a bit until I backed out of it. Letting out both runs still resulted in decent traps. Here they are:
Run #2
60'----2.642
330---6.652
1/8---9.537
MPH--89.13
1000-11.901
1/4---13.842
MPH--116.98
Run #3
60'----2.551
330---6.236
1/8---9.074
MPH--88.84
1000-11.458
1/4---13.415
MPH--116.21
Hopefully next week I will have some 285's (I have 245's now) and a little better traction. Oh well, it was fun.
Old 06-18-05, 09:13 AM
Aristo300
Aristo300's Avatar
Originally Posted by Easy2speed
Here's how it went:
60'----2.421
330---6.181
1/8---8.921
MPH--91.13
1000-11.219
1/4---13.122
MPH--118.87
The car runs strong... I won't mention my time slips
Old 06-18-05, 03:27 PM
Arizona
Arizona's Avatar
MT ET Streets are your best friend
Old 06-18-05, 07:27 PM
Todd1225
Todd1225's Avatar
Nice traps! Lets see some more vids and pics of that hot rod!
Old 06-19-05, 01:11 PM
Bean
Bean's Avatar
ET streets will destroy a W58
Try a LSD, it will make all the difference in the world
Old 06-19-05, 03:45 PM
Arizona
Arizona's Avatar
Woah, ur still on the w58 , Yeah scratch my idea that thing will pop like the weasle. LSD And just practice your launches in deserted parking lots.
Old 06-19-05, 06:01 PM
Todd1225
Todd1225's Avatar
Well, the huge front mount takes away from being a "sleeper", but I imagine you still suprise alot of people on the street and on the strip!
Old 06-19-05, 07:08 PM
got_trd
got_trd's Avatar
Nice times.. LSD and Drag Radials would do the trick. Bring that 60 foot down. I thought mines were bad
Old 06-20-05, 11:33 AM
Easy2speed
Easy2speed's Avatar
The car has a severe vacuum leak. When you floor it, the car just bogs. You have to ease into the gas and let it barely make boost then go full throttle. That makes launching a chore. I am no amateur at racing - I have had about 7 different fast cars and have made over 500 drag strip passes. I can only go full throttle after about 1-2 seconds into the run. When the car hits full boost in second, it goes sliding all over the strip. I only ran the car in its state to see about what it traps. Once I get some free time to find the vacuum leak and convert the S-AFC to a MAP sensor, I will run again with some good 1.8-1.9 60's. If I can go full throttle the whole run and go into fifth it should run a mid-high 11 with about a 122-124mph trap. It will be fun.
MRxSLAYx
IS F (2008-2014)
57
01-24-11 08:58 AM
sickISF
IS F (2008-2014)
10-14-10 01:58 AM
DRE1615
IS F (2008-2014)
34
06-09-08 09:45 PM
Lextasy89
12-09-07 06:14 PM
Quick Reply: Ran a Bit Better at the Track Last Night
