NA-T TE44 turbo head gasket advice?
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Car = Lexus SC300 5 speed
Goal = 400rwhp max with widest powerband & soonest power delivery in rpm range
1) I want to sacrifice as LITTLE low end power as possible, so I don't want a headgasket that is too thick. Will the Stock tt (2JZ-GTE) head gasket be ideal for me, or is there a specific head gasket thickness & brand that will better help me achieve this goal?
2) While I'm replacing the head gasket are there any other gaskets/seals/etc it might be adviseable to change on a 130-150k mileage engine?
PARTS:
MAP-ECU (MAF removed)
DaveH manifold + DaveH midpipe + shorty DP
Tial 40mm wastegate (recirculated back into exhaust)
ARP Head Studs
HKS SSQV BOV
TE-44 turbo
RX7 550cc injectors flow tested to safely flow 605cc
Supra tt fuel pump
Supra stock tt sidemount intercooler
Generic manual boost controller
EGR Block Off Plates
ABS Heat Shield
Turbo Blanket
Thanks in advance for answering my questions
PARTS:
ARP Head Studs
HKS SSQV BOV
TE-44 turbo
Supra tt fuel pump
ABS Heat Shield
Turbo Blanket
PARTS:
ARP Head Studs
HKS SSQV BOV
TE-44 turbo
Walbro GS3341 255lph fuel pump OR supra tt fuel pump
ABS Heat Shield
Turbo Blanket
PARTS:
ARP Head Studs
HKS SSQV BOV
TE-44 turbo
ABS Heat Shield
Turbo Blanket
if you are willing to spend the cash on a decent turbo set up, why skimp out oh the headgasket? most aftermarket ones go for about $200-$250, new ones are about $100 from the dealer if im not mistaken. dont use a used headgasket. just do it right once, and then you wont have to worry about it. just my $0.02
Okay,
I'll use a new head gasket. Someone mentioned that the NA sc300 compression in the motors is higher than the NA supra motors? is this true?
I've heard of people boosting fine on 1 bar with stock tt headgasket (1.2mm) on a 2JZ-GE motor, but now a few people on the forums are telling me the 1.6mm apexi or hks headgasket is better for my goals?
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Okay,
I've heard of people boosting fine on 1 bar with stock tt headgasket (1.2mm) on a 2JZ-GE motor, but now a few people on the forums are telling me the 1.6mm apexi or hks headgasket is better for my goals? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
good luck man!
I've been reading about this device: MSD 6BTM that enables users to retard engine timing 1-3 degrees per pound of boost. How much max RELIABLE boost could I run with NA stock headgasket and this MSD B6TM? It seems like it would help me raise rwhp reliably on stock motor without doing a headgasket upgrade.
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
forgot to mention i'll only be using 92 octane pump gas max...but from your statement, the 6btm won't really help me add much boost so stock tt headgasket seems like the way to go for 400rwhp on 92 octane pump gas safely?
Also,
I'm just curious what would be required to build a 10:1 compression 2JZ-GE NA-T with this turbo and 400rwhp goal? Would I need stronger rods and pistons only?
...couldn't find any info when I searched
Originally Posted by 2jznat
10 psi on race gas no higher
try 16-18psi with race gas
I ran 10psi all day long on 93 octane and 12-13psi on 93 octane + toluene
Stock TT headgasket will get you ~8.75:1 compression or so... thats PLENTY for making 400whp... hell even 500 or 600whp
if you are running 92 octane and dont plan on making more than 400whp, i'd just suggest using the stocker.... (gasket i mean)
now if you've psyched yourself up for it, you might as well go ahead and do it... because you can also clean up all your other parts and ensure a perfect install with regards to the injectors, FPR, etc...
stock TT headgasket would suffice perfectly fine for what you want to do... but a 2mm Greddy would ensure that you have a 8.5:1 (not THAT much difference honestly)
a MSD BTM works great if you're going to run higher boost on stock compression (like 15-17psi on race gas)... but if you're upgrading the headgasket, there's no point honestly... just get the tune right (with whatever fuel controller) and you'll be fine
and last but not least: do not use a USED headgasket... just fork out the extra cash for a NEW one... TRUST me.... new parts are always better than used parts (unless by the term used, you mean taken out of the box
